Question about LG LRSC21934 Side by Side Refrigerator
Inside of door when you open lg refrigerator is very hot
Inside of door when you open refrigerator is very hot
  • barbara_fran May 26, 2009
    This is very hot, almost burned my hand. It's about 4 years old
  • barbara_fran May 27, 2009
    the frige runs continuously
  • 1,543 Answers
I suspect you are talking about the area between the doors. Refrigerators use a loop off the compressor to warm this area to prevent condensation from forming there. Older refrigerators sometimes used an electric heater there, but of course that increases energy consumption. You will notice that the area is much warmer when the compressor is running. All this is normal, and saving you energy.
Posted on May 26, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg May 26, 2009
    Is your refrigerator running continuously? If not, have you felt it after the compressor been off for 15 or 30 minutes?
I have an LG American fridge freezer GRB207TUJA which the edge where the doors close on is very very hot
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | LG Refrigerators
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
LG Model lfx28978sw french door freezer door hard to open
its likely you have frost inside your tracks. best option for you is to defrost the freezer and let the ice inside the tracks thaw. then after the ice thaws the tracks should work better. If that dosen't help you may need new tracks for the freezer door
Aug 03, 2013 | LG LDC22720ST Stainless Steel Bottom...
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Mar 26, 2011 | LG Refrigerators
We have a LG french door refrig, Model #LRFC25750TT. Ice forms in the bottom of the freezer which causes the door to stick when opening and closing. It appears that water may be coming from the vent on...
You have a frozen drain tube. Remove the back cover after unplugging the unit. Locate the drain tube running down to the drip pan. If it is frozen, thew it with a hair dryer. In the inside, find the drain hole and pour hot water in it until it drains properly. I f it happens again your defrost element is too far away from the aluminum drain pan and needs to be GENTLY lowered closer to the drain
Dec 03, 2010 | LG LRFC25750 Refrigerator French Door
LG LFC25760SB french door light off but hot
try to replace the bulb/ door switch
Nov 13, 2009 | Refrigerators
WHY IS THERE ALWAYS ICE ON THE BOTTOM OF THE FREEZER.IT GETS TO BE SO THICK THAT THE DOOR DOESN'T SEAL?
You have a frozen drain. Remove the cover on the bottom back and locate the drain tube and thaw it with a hair dryer. Find the drain inside the fridge and run hot water thru it until it opens.
Oct 26, 2009 | LG LRBN22510WW Bottom Freezer Refrigerator
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Ice despenser door not opening
I had this problem. There is a piece of ice jammed in there that is blocking the door. try pouring some warm water into the hole from the inside and naking sure the path is clear.
Apr 14, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LRSC21934 Side by Side Refrigerator Logo
827 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
