Question about HP LaserJet 1200 Printer
HP Laserjet 1200 will not print if installed on new computer
I set up a new computer (Dell running on Windows XP) I plugged in the HP Laserjet 1200 Printer and it automatically installed the printer. It appears it recognizes it. If I am trying to print a test page, it returns an error message and says that it could not print and the Printer Que is full. Does anybody have a solution for this problem?
Thanks so much!
  • 52 Answers
Try printing a self test directly from the printer.
If its ok, use a new cable, if it still does not work, re install the driver, if it still does not work, try from another computer.
Posted on May 26, 2009
  • 661 Answers
Check to see if you are trying to print offline...
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
Jul 13, 2010 | HP LaserJet 2840 All-In-One Printer
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
I have installed Windows 7 and my hp laserjet 1200 series will not print on a command from the computer. I have installed the program and reinstalled the program. During the installation I'm told to check...
Click Here for the proper driver for your hp 1200 and the windows 7 operating system, I'm assuming you have the 32 bit version but if you have the 64 bit version go back one screen and click the windows 7 64 bit driver. I also recommend you stick with pcl 5 as opposed to 6 as 6 has been known to be quite a bit wiggy...If this helps you out Please mark this a FixYa!!
Nov 29, 2009 | HP LaserJet 1200 Printer
I cannot get my printer to work with my new dell inspriron computer. My printer is a hp 1100/1200 series all-in-one. Are these two compatibile.
Did you run the printer install CD before plugging it in ,your new laptop needs the printer software to be installed in order to comunicate .
Is it a deskjet or laserjet?
Jun 23, 2009 | HP Office Equipment & Supplies
Cant connect (or see) my LaserJet 5000 on Windows XP
In XP go to START > CONTROL PANEL > NETWORK CONNECTIONS > LOCAL AREA CONNECTION
you should see a menu showing your network card and a window that says stuff like Client for Microsoft Windows. Below that window is an INSTALL button. Click on that and double click PROTOCOL. Select IPX/SPX NetBios and hit OK. You'll probably need the WindowsXP CD to finish installing the protocol.
The LJ5000 is a very old printer and if I remember correctly, it uses the IPX/SPX Netbios language to communicate through a network. Netbios is not installed by default in XP.
May 08, 2009 | HP LaserJet 5000 Printer
Problem connecting LaserJet 5L to new HP Pavillion laptop
I have an HP 5L and Vista Premium also. If you would tell me where you did find the driver, I will install it on my computer and possibly solve both of our problems.
Thanks
Mar 17, 2009 | HP LaserJet 5L Printer
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
How do i install hp laser jet 1018 printer
hi johnboy
you can download the driver from here hp 1018
select your windows to download .
riz.
Jun 09, 2008 | HP LaserJet 1018 Printer
HP LaserJet 1200 Printer Logo
271 people viewed this question
Seeker5211
Seeker5211
