Bad and cracking sound
Hello, I'm the owner of a SONY Amplifier TA-F419R. Since a couple of months I don't get any more clear sound. Very quickly after I turn the amplifier on and select a sound source , I start to hear a cracking sound put onto the music signal and the music volume is strongly reduced. Wathever connection I use, or whatever setting with respect to Bass, Balance, Speakers, etc. I always get the same result. Even when using the headphone jack, it gives the same result. Might someone be able to indicate me if this is fixable and in what way, or if I will need to buy myself a new one?
  • Dimitri VN May 28, 2009
    Thank you for your feedback Grubhead.  I indeed have the problem on both channels.  I already took the cover off, dusted everything (something which was clearly necessary) and looked for anything abnormal/burnt.  Unfortunately so far I haven't seen anything out of the ordinary.  I'll check your suggestion on the IC.  Right now I have a large aluminium heatsink sitting centrally in the amplifier.  I'll have a look tonight on which components are connected to it for thermal management.
  • Audio Player... Master
  • 5,484 Answers
By the sound of it the noise is in both channels yes? If so then it is caused by something that is common to both channels. The cost of repair will depend on if you can fix it yourself, or if the parts are expensive or even available, to yourself or a repair person. You can determine some of it yourself by taking the cover off. If you see on a metal heat-sink a black IC with a load of pins coming out of it (often with the letters STK and numbers) then that might be the cause. If you see transistors on the sink then it's likely to be something else.
Take a look around and see if you can see something burnt or not normal. It won't cost you anything. Make certain the plugs out!
If you do see that IC with the number Google it! You'll get an idea of cost, even if you send it for repair!
Posted on May 27, 2009
HOW TO CONNECT THE SONY TA-FLX9W MODEL AMPLIFIER
Google search for a Sony owners manual using your model number. Get an owners manual download it and read it.
Dec 25, 2013 | Sony Audio Players & Recorders
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
I have just bought a used Sony Integrated amplifier TA- F210 and it didn't come with the owner's manual so I don't know the RMS wattage to enable me connect speakers with the appropriate wattage. Could...
Hi, I brought a Sony TA-F-210 new back in 1990 $ 650 NZ , and has been a very .. very good amp. Earthquake ruined it !! I still have the owners manuel and it says for UK and other countrys DIN, 1 kHz, 8 ohms . 70w + 70w . or . 20Hz-20kHz THD 0.05%, 8 ohms . 50w + 50w Hope this helps. Have been running big old 3 way 8 ohm 50w speakers for all its life and it grunts.. or did !! Nobody belived me I was running only 50w speakers !! I dont know what I will replace it with.. You will enjoy. Might look for another one ! Wayne.. NZ CHCH
Nov 26, 2010 | Audio Players & Recorders
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
Sony amp TA-F417R no sound, when device on temp it may work
My first suspect would be the output relays. These can get corroded over time and the classic symptom is that you get no sound at low volume levels and high volume levels will kick in the sound. There may be other issues as well such as poor solder connections. If you don't have any experience with this type of gear, have this checked by a service center. The cost should be minimal.
Dan
Jul 17, 2009 | Sony STR-DE595 5-Channel Amplifier
HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
Sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
Oct 08, 2007 | Audio Players & Recorders
Sony TA-F210 amplifier no sound
bring data sheet of this ic from the net-check supply voltage(vcc or vdd)-check ground.apply audio signal and test if it is present in input pins after that check your signal in output pins.have a visual inspection around the ic for burnt resistors or bad capacitor. if every thing is fine replace the IC.
Oct 05, 2007 | Audio Players & Recorders
189 people viewed this question
 Grubhead
Grubhead
