Question about Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer
Starter cord not recoiling
I have a Poulan bush cutter PP325 and I tried to start pulled the cord which did not recoil I cannot get into the housing to try and repair this.
  • 376 Answers
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
Posted on May 26, 2009
Husqvarna pull cord
remove the recoil housing and add an extra turn on the recoil cord on the spool to take up the slack.
Nov 27, 2013 | Stihl Saws
How to fit new starter cord
remove recoil cut off old rope take new rope burn end till pointy push threw recoil and into hole in pulley tie knot on pully side add handle pull string between pully and outer shell rotate pully counterclockwise 4 times with rope you puled from out in between pull access back out of the housing till tight release or go to a shop they normally only charge ten bucks
Mar 05, 2013 | Makita DPC6410 64cc 12" Power Cutter
If you trying to pull the starter to start it doesn't pull out
Hi, sometimes the recoil rope gets a little tangled inside the housing if the cord is allowed to snap back after pulling. You need to undo the screws that hold the recoil on the motor and inspect the rope inside. If you cannot pull the rope freely while it is detached, then the problem lies with the recoil. In this case try to find the tangled cord and undo it. Test that the coil works before reinstalling it. It should work fine. If you pull the recoil while it's detached and it moves freely, then the problem lies with the engine itself. This would indicate a seizure and requires a complete tear-down and rebuild. Good luck.
Nov 18, 2010 | Ryobi Garden
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull cord won't recoil
the recoil spring may have broken and should be inspected and replaced
Jul 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
My recoil starter will not pull back the recoil cord. the mower will start and run, but the cord will not go back into the recoil housing.
Go to smalleng.com they have free how to videos for just your problem, check it out it's a pretty cool website.
Nov 24, 2009 | Garden
Poulan wild thing recoil froze up
You may need to replace the recoil assembly, check with poulan for availability.
Sorry I couldn't be of greater assistance.
Apr 17, 2009 | Garden
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer Logo
486 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
