Question about Jandy Digital Lite2 Lj250 Btu Heater, Natural Gas
Tandy digital controller display is flashing on and off
The display is flashing info eg. temp location 188 E
and time area 18:88 PM
    Champion:
  • 246 Answers
Whoa bad board may be but first check the thempetore sensor is at around 10k omh if bad replace first read the manual to change the time if doesnt chage replace the board
Posted on Sep 01, 2009
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How chang the time
To set date and time for Sharp UX 188 Press:FUNCTION then 3 then * * * * Display: DATE & TIME SET Press the START key: Enter two digits for the Month (01 through 12). Enter two digits for the Day (01 through 31). Enter four digits for the Year (EX: 1998). Enter two digits for the Hour (01 through 12). Enter two digits for the Minute (00 through 59). Press the " " key for A.M. or the "#" key for P.M. When finished, press: START key and STOP key
Mar 30, 2011 | Sharp UX 188 Thermal transfer Fax
CLICK HERE for your user manual.
You can save or print it for further reference.
Setting the clock is inside. (page 6) as follows...
Setting Clock Time and Calendar
Important - While setting the time or calendar, if you do not press the appropriate buttons
(as explained below) within approximately 8 seconds, the display will stop flashing. If this
happens you must follow the instructions again from step 1.
Setting the Clock Time
1. Press and hold the Time Set Button until the display begins flashing.
2. Press the FWD/Month or REV/Date Button to select correct time. Remember to
set the correct AM or PM. The PM Indicator is located on the upper left side of the time
digits (there is no AM indicator).
3. Press the Time Set Button again to return the display to normal mode. You can also
allow the display to flash for approximately 8 seconds to return to normal mode.
Note: While setting the time, if you press and hold the FWD/Month or REV/Date
Button the minutes will begin counting at a moderate pace, then get faster. This will
assist you in easily setting the time quickly and accurately.
Thanks!!
Sep 30, 2010 | Timex T158W Clock Radio
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Emerson Radio CKD9906
I hope this will help you, I just found the Users Manual to this Model online myself, as I needed info on setting the Alarm.
I am also going to upload the full Manual, just incase anyone else needs it.
Cheers!
Peachess
Setting The Time Of Day
• Connect the power cord to your AC outlet. Make sure to use an outlet that is
always ‘live’. Do not use an outlet that is controlled by a wall switch.
• When the unit is plugged in for the first time the
display will show flashing “12:00” (AM).
1.) While the display is flashing, press the HR. button to set the hour. Be sure
to observe the PM indicator to set the hour correctly. If the PM indicator is ‘On’
the hour displayed is PM.
2.) Press MIN. button to set the minute correctly.
3.) Press the TIME button once. The time is set.
The display remains ‘On’.
Note: You may proceed to re-set the time again by pressing the TIME button
once during Power-off or CD, FM, AM, Buzzer modes.
Important Notes !!
If you press and hold the TIME button any time, the clock will change to
European 24-Hour format, and 12-Hour USA format.
May 10, 2008 | Emerson (CKD9906) Clock Radio
I have a sharp carousel microwave and need to set the digital clock on it but dont know how. could someone please help.
The easiest way I can remember is to turn off the power, then back on... this will make the display flash, then press stop/clear.
Then press clock, enter the time eg: for 9 am or pm enter 9.00 and press clock again.
Hope this helps.
Apr 25, 2008 | Microwave Ovens
Setting the time
This info is in the pdf manual (pg 5) posted on the FixYa page for this problem (about middle of the page). I can't paste in the graphic but this is what the page says:
Setting time: (graphic is of the top of the radio with the buttons)
1. Press the SET button, the “ : ” will flash on the display .
2. Press REV (L arrow) or FWD (R arrow) to set the time.
3. AM or PM icon will show beside the time.
Tip: No icon will be flashing if all selectors are set. If you see any icon flashing on the display, press the SET button repeatedly to confirm everything is set correctly.
Oct 01, 2007 | GE 74801 Clock Radio
Jandy Digital Lite2 Lj250 Btu Heater, Natural Gas Logo
295 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
