Question about Xerox Phaser 8400 Laser Printer
Says paper jam and there is none. wont let me print. tried everything
The printer is saying that there is a paper jam. I have done everything it has told me to do and there is no paper there. I have also started the printer and unpluged it and it still says there is a paper jam. How do I fix this problem so that I can print? I am a volunteer at a non profit organization called Samaritan's Feet, so there is no funding for fixing this problem. Please Help. Thank You.
  • 52 Answers
When you removed thejammed paper the paper sensor might still be stuck in an active position.
Have to pull it back in place. Just have to follow the paper path and find out where it is.
Posted on May 26, 2009
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
Cannon MP370, says clear paper jam, none seen
i know that happens to me check that everything it as it sould and resated
Dec 29, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Says I have a paper jam when there is none
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
The printer says I have a paper jam. There's none,but it won't wo
One of the paper sensors is probably stuck. Some disassembly may be required to get to them. They are normally small plastic rockers that will let a small IR device either allow a beam of infrared light to pass or block it. On this printer, I would guess that there are 2 of them. One located at the paper feed so it knows if there is something in the tray or not and the other is probably located at the back where the paper curls back around to pass beneath the print area. There could also be a thrid at the output tray, but with this particular model, I kind of doubt they put one there.
Apr 14, 2009 | HP PSC 1215 All-In-One InkJet Printer
Says paper jam but there is none. pixma mp450
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Feb 21, 2009 | Canon Pixma MP450 All-In-One InkJet...
Monitor keeps saying remove paper jam --none can be found !
Look at the rear of the machine, it may have an access door.
Jan 06, 2009 | HP Photosmart C4150 All-In-One InkJet...
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
Epson cx7800 error e-04
make sure the ink cover was down tight. Shut down the printer open it up and resecure the ink cover. That has fixed this error in many a case.
Jul 31, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper jam, when there's not a paper jam?
there is a small micro switch , when paper is loaded that switch
is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Xerox Phaser 8400 Laser Printer Logo
484 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
