Question about Mtd Garden
MTD 12.5 HP Ride On Mower won't stay running
My MTD Ride on Mower (model 131-660F00/C181H1) won't stay running. It starts and makes one pass around my large yard then sputters and dies. If I adjust or put the choke on it stays running for a little longer but eventually dies out. The ride on is at least 20 years old about now.
Is this a carburetor issue?
Thanks for any help you can provide.
Donna
  • 420 Answers
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
Posted on May 26, 2009
Mower machine, 6.5 hp , model 20016 , 22" high-wheel,. so question is :gasoline pass from carburetor through air filter,what i do?
Its quite common to see fuel in or around the air cleaner to carb casting. Side mounted carbs on Tecumseh and Briggs tend to spray a little back. If its running back then get someone to strip and clean the carb, its got some debris in it.
Sep 29, 2016 | Mtd 22" Yard Machine Push Mower
14.5 HP MTD MOWER WON'T TURN OVER
Can you turn the motor over by hand? Make sure it's free and can turn. Is starter drive engaging into flywheel. If mower was run with low oil or on a slope it may have seized up.
Jul 25, 2013 | Mtd Garden
Won't stay running
sounds like carburetor is clogged or has something in the jets or possibly fuel line or tank is clogged. check fuel tank and line to make sure fuel flows easily then carburetor cleaning and rebuild may be required
Aug 24, 2012 | Mtd 22" Yard Machine Push Mower
Mtd yard-man ta4145 ride on lawnmower manual
Try SearsPartsDirect.com they may be able to get one
Aug 20, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Mower starts but won't stay running
check the inside of the cap. Check the underside of the gas cap for a cardboard disk. Remove the disk, and try starting again. My mower had same problem, and I removed the disk and suddenly it ran like there was no problem at all.
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
Just replaced head gasket, now has to much compression and won`t wind over fast enough to start. have had starter checked and seems ok .10.5 hp briggs and stratton motor in a murray 32 inch ride on lawn...
A head gasket will not greatly increase the compression in a a Briggs motor.
My question is Why did it need a head gasket to begin with?
Will bet it was not running...
A more likely cause if not a fuel problem is to check engine oil if that is good remove the wire from the low oil sensor and see it it will start up for you.
r/
David
Jan 23, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
L have a Bolens 12 Hp ride on mower purchased new 1992 l have not used the mower for the last 7 years due to update to a larger mower.L'd like to have the bolens as a spare mower. What is missing from my...
Bolens is now owned by MTD. Find parts for your machine at http://www.bolens.com/webapp/wcs/stores/servlet/topcategory_10151_15953_-1 or your local MTD/Bolens dealer
The bigger challenge you will have is getting the engine running again unless you have maintained it the past 7 years. My free advice is get the motor running and make sure the tractor still functions before you start adding accessories. Once you have driven it around the block once or twice, then get the parts you need to operate the deck. I think these parts will be a little pricy.
I say these things because of a similar experience with a International Cub I got. I spent a lot of money to get the mower running before I got the tractor running, reliably. I didnt get my fair value from my $ as a result. I then bought a geenuine Troy and have never looked back. (MTD owns the Troy brand now also.)
Good luck with your project
Thanks for using FixYa.com
Please vote
positive comments appreciated by volunteer question catchers.
a
Dec 12, 2009 | Radio Communications
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
864 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
