Question about GE 25841GE3 5.8 GHz Twin Cordless Expansion Handset
MSG WAITING OFF/ON is annoying
I have a set of GE cordless phones (model# 25841GE3-A). Whenever I try to scroll through the caller ID list OR if I start dialing a number before pressing "Talk", I get this stupid message, "MSG WAITING OFF/ON" (either OFF or ON). Apparently it's a visual call waiting indicator that lets me know if I have voice mail or not. It is NEVER helpful, only annoying, because I have to wait several seconds before starting all over again with whatever I was dialing. Is there any way to turn this off? I've heard that it may even be my voice mail provider's fault (TWC), but they don't even know about it. Help.
I need a manual for the GE 40-channel 2.4 GHzCall Waiting Caller ID Cordless Telephone - Can You Help??
Since you declined to specify the model of your GE system, I can only direct you to select it from this list in order to download a copy of the manual.
Mar 26, 2011 | GE Lands Phones
Ringer does't sound, manual says "switch it on". Doesn't tell me where the switch is. GE. Model 28811 series DECT 6.0 cordless.
With the phone off, press the #/pause button. The display will show "set ringer level 5", using the caller ID/volume button scroll to the level you want. Press the #/pause button to save your setting.
Dec 11, 2010 | GE Lands Phones
Model 25942EJ3-C
Try this:
1.) Make sure the answering system is on.
2.) Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3.) Press key (8) to enter Time/Day set menu using the handset.
4.) To set the Hour, key in (00)-(12), like 08 for 8 o'clock.
5.) To set Minutes, key in (00)-(59), like 15 for 15 minutes after the hour.
6.) To set AM/PM, press the CALLER ID-VOLUME up or down buttons.
7.) To set the day of the week, press the CALLER ID-VOLUME up or down buttons.
8.) Press #PAUSE/ringer button to confirm the setting.
Hope this helps you out! Hal
Apr 16, 2009 | GE 26938GE1 Cordless Phone
RE: Model #kx-tga931t telephone Panasonic brand
Press: menu scroll down to talking caller id press select scroll down once till you see "off" press select You have to do this on each handset
Dec 21, 2008 | Panasonic KX-TG5583 Trio Cordless Phone
Delete MSG WAITING OFF from screen
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 19, 2008 | GE -27938GE6 2.4GHz Call Waiting Caller ID...
How to activate caller ID after moving the phone
I know it seems like an obvious thing but did you make sure that you have caller ID on the line from your telco provider?
Oct 14, 2008 | GE 25952EE1 Cordless Phone
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Caller ID Problem on the GE2811 Twin cordless phone system
How to get the caller ID to work on the additional GE DECT phone handsets. You must follow these steps in the exact order :
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes. reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in.
It takes about another 10 minutes after that before all phone handsets start recognizing caller ID.
Oct 23, 2007 | GE 28111 Cordless Phone
Caller id
see if this corrects the problem. . .press and hold menu/voice mail button to enter the menu. . .press the zero/oper button to go to the message waiting programming option. . then press the edit/flash button to reset tne Message Waiting Indicator. . "DEL" will begin flashing..press the redial/save/ pause button to delete this indicator.. . a long beep will sound to confirm a reset/removal of notification..press menu button to exit. Theo
May 31, 2007 | Xact Communication XG2206 Cordless Phone
GE 25841GE3 5.8 GHz Twin Cordless Expansion Handset Logo
75 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
