Question about Flotec 1/6 Hp 1260 Gph Utility Submersible Pump
Correct placement for Flotec Utility Pump
I recently bought a utility pump. Last night we had a torrential downpour - the pump turned on and off but did not stay on for a long enough time to stop water from coming into the basement. We have it placed by our French drain - should it be in the drain? top of the drain? next to the drain? How do we keep the pump on for a long period of time?
  • 634 Answers
Should be in drain basin to work properly and check that float moves freely.
Posted on Jul 17, 2009
Flotec FPUS1860A utility sink pump won't stop running
Either the float is stuck or the float went bad...
give it a kick and make sure the float has dropped down and is not hung up...
If that don't work then unplug it and replace the float switch...
heatman101
Sep 17, 2010 | Flotec 1/4 Hp Automatic Utility Pump
Pump quite working
Start by checking float switch
Jan 09, 2010 | Flotec 1/4 Horsepower Sink Pump System
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Flotech utility pump clogged. took top off and
unless you are a electriciani would highly recommend you do not touch this... the green wire is a earth and the two other wires are your active and neutral if you wire this back to front it will spin the oppisite way and could cause internal damage to the pump could spin impeller off or worse...
Regards
Brad:)
Sep 21, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
I need a power cord for my 1500 gph 1/6 HP Flotec submersible pump. where can I get one? Cat # u2 Serial # 50833
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Feb 17, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Flotec 1/6 Hp 1260 Gph Utility Submersible Pump Logo
487 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
