Question about RCA HD52W58 52" TV
RCA will not turn on
My tv will not turn on.  It is about 2 and a half years old.  Green light turns on for a few seconds and then goes back off. You can hear a noise when the light comes on and after it goes off it will repeat 2 more times then
nothing.  Could this be some sort of loose wire or something?
Re: RCA will not turn on
I had this problem on My RCA tv, what I found was a couple of bad green capacitors in power suply there are around three of them I just replaced 2 of them if I am not mistaken one of them is C120 but if not change all three this are the value of the ones I replaced 2200uf 16v and 220uf 35v, if you see on top of the green capacitors you will notice they are bad.
My tv is working for more than a months and I had the same problem as you are having.
Posted on Jul 15, 2008
0 characters
3 Points
Tv will not turn on green light flashes for 10 seconds then goes to red
Tv's are designed to check themselves for problems when 1st turned on. If something is shorted and a voltage goes to high they will not turn on fully. It sounds like your set is trying to turn on yet sees a problem then goes back into standby mode. This can be cause by many different circuit problems. Generally repairs can range from $75 to over $200 depending on problem and brand. I only recommend repairs if half the cost or less to fix. Since your ? only stated it's a CRT. I would recommend your purchase a new LED LCD TV. CRT (cathode ray tube) Tv's are now old technology. You could probally find a new set for the price to fix the old.
Jan 20, 2014 | Standard (CRT) Televisions
I have a 20 inch true flat screen RCA tv is about a year old. After you turn in off, later on it turns itself back on. and sometimes it turns itself off after being on for a short perion.
I have the same problem with the same size 20" RCA tv. Mine is a little over 2years old. After turning itself off and on whenever it felt like it, now it blinks off and on nonstop every few seconds and nothing makes it stop......please help
Dec 14, 2008 | RCA 20F410T 20" TV
52 HD Samsung tv turns off
I have the same problem with my 56" HD Samsung. It shuts off automatically and then on the power button the word Lamp is light up in green. Sometimes I can turn it back on but other times it won't and I have to wait a bit. It's been embarassing a couple times when people were over for a movie. I believe it might be some kind of overheating problem but would like someone to confirm this.
Jul 06, 2008 | Samsung DLP HL-P5663W 56" TV
RCA F32450 TV problem
color ic on the blink.
Jun 16, 2008 | RCA F32450 32" TV
My tv turns on turns off few seconds
has capactors bad,cp150(2200mfd@16v)this located on main chasis towards back in the middle
Apr 05, 2008 | RCA HD52W58 52" TV
Tv will not turn on
the rca itc222 chasis has a processor that shuts the set down when it detects a problem for Safety. it can be one of about 30 problems. the computer also records the errors in memory and a technician can interface with a computer to read these errors. after the set attempt to come on 3 times then the set locks up and you have to unplug to reset.
Jan 05, 2008 | RCA HD52W58 52" TV
Powering on
needs a new flyback
Jan 01, 2008 | RCA HD52W58 52" TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
RCA 32V420T (32 inch)
I think that vertical deplection IC of you tv set is shorted. Please check also the YOKE of the unit, its maybe grounded.
Sep 10, 2007 | RCA 32V420T 32" TV
Constant clicking every half-second as soon as you plug it in.
I have the same problem-still far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Aug 29, 2007 | RCA F38310 38" TV
RCA HD52W58 52" TV Logo
346 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
