Question about Kenmore 53582 / 53584 Side by Side Refrigerator
Kenmore side-by-side dispenses water but makes no ice.
We have a Kenmore, tag model# 106.53582300. The ice maker stopped working over time - at one point, we were getting "hollow" ice-cube, which I think means water was trickling in too slowly. Now, no water is getting in at all. Checked the shut-off arm, it is in the down position. I disconnected the tube that goes from the valve at the bottom up to the ice maker and no water came through it, so I think the problem is that the valve won't open. I don't know where to go next, though. I'm thinking the valve could be jammed/clogged, but before I spend cash on a replacement, I want to make sure the valve is getting the signal to open/close, and that it's not an electrical or logic problem. I'm also assuming the valve isn't serviceable and can't be repaired. Any thoughts on my next step would be greatly appreciated. Thanks!
  • 1122 Answers
SOURCE: ice maker making ice
pull the water supply tube in the freezer out and see if it is frozen up,let me know more-mike
Posted on Oct 12, 2008
tech master
  • 120 Answers
SOURCE: Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Posted on Oct 17, 2008
tech master
  • 120 Answers
SOURCE: Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
  • 531 Answers
SOURCE: Water not dispensing from door. Icemaker works and ice is dispensed
water valve
Posted on Apr 05, 2009
SOURCE: ice maker not working, 2005 kenmore side by side
could b couple of things wrong tstat inice maker may b bad motor may b bad. best solutionis to replace ice maker
Posted on Oct 12, 2009
The ice maker for my Kenmore Refrigerator model #106.56544400 has stopped working
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Sep 03, 2011 | Kenmore Side by Side Refrigerator
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water works the ice is not
Your water valve is stuck open. Is it for the ice maker or the water dispenser? It could be the switch in the door calling for water instead of the valve. Does it stop when you unplug the refrigerator?
Sep 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53582 / 53584 Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
