Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water despenser water does not flow....ice works fine...new filter installed...still no flow ice maker works but no water
  • charles_lang May 28, 2009
    Hello Wolverine,
    I did get the front cover off and tested the switch it lets power threw. Found the relays in the back and power goes in it hums or atleast vibrates but with the out going water line of nothing coming out. I was also wondering if there is a filter that could prevent water from flowing out the dispenser side and alowing the ice water to flow. Also are they seperate selenoid valves or do I need the pair of them and replace them both? Thanks for the response. CLang
  • 420 Answers
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
Posted on May 26, 2009
3 Suggested Answers
  • 409 Answers
SOURCE: water despenser
hi there,
check to see if you have a leak in the water line. the line runs from the wall to the icemaker. do you have any leaks on the inside of the door? any frost build up? im assuming that you have a side by side fridge with an icemaker.
Posted on Oct 11, 2008
machinetech7
  • 1344 Answers
SOURCE: no water flow to ice
Its odd that both parts of the valve went bad at the same time. Personally sounds as if your water filter is clogged up and needs to be changed. I would do that first, before trying to change the water valve itself.
Posted on Dec 08, 2010
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
Ge mod GSS22GRC SS the ice maker works fine but all of a sudden the water despenser does not flow....I since changed the filter that did not help
Start by checking the water supply going to the fridge:
  • Turn off the water at the saddle tap valve.
  • Disconnect the water line in the back of the fridge. Place the disconnected end in a bucket and open the saddle tap valve.
  • Observe the flow rate–water should shoot out vigorously. If not, then the saddle tap valve is probably gunked up with sediment and you’ll need to replace it.
Oct 11, 2008 | GE Refrigerators
No water flow to ice maker or water despenser...water lines are clear the filter is clear..could problem be water inlet valve ( dual valve controls water flow to ice maker and water despenser.
Dec 08, 2010 | Whirlpool Refrigerators
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
The ice from the ice maker tastes terrible, the water from the despenser is fine just the ice is a problem
remove icemaker and check that you have no eroding of teflon coating. you may install a quaity charcoal filter.
Jul 25, 2009 | Amana Refrigerators
No Ice is being made. Water is being despensed at the door but it seems that no water is going to the ice maker. Have good water flow to the pump.
Is the ice maker turned on?  The on/off switch is located on the top right side of the freezer compartment.  The manual says that there is a sensor beam that passes from one freezer wall to the other to shut off ice making when the bin is full.  Check to make sure nothing Is blocking that signal beam and that the bin is correctly installed.
May 30, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
Water despenser
hi there,
Oct 11, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
301 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
