Question about Microsoft Windows XP Home Edition
Access to facebook
To access facebook i have to run my windows in safemode if i run in full windows ir will not let me access the site
  • Frank
    Frank May 11, 2010
    check you firewall setting. it is in control panel>> sesurity.
    President:
  • 688 Answers
You may have your security settings to high and your not getting a cookie or something.
go into your window control panel and set your security settings to medium or medium high
this will let you move to sites easier.
also parent control will do this to. turn off parent control
Posted on May 26, 2009
To Block the Access to certain links
yes. using a simple text editor like notepad simply add entries to the file:
c:\windows\system32\drivers\etc\hosts
the entries should look like this:
127.0.0.1 www.siteiwantblocked.com
that IP address is the "localhost" and will result in and error or if the computer is running a web server it will go to that site.
Nov 25, 2013 | MPC Computers Computers & Internet
Whenever i turn on my laptop , its not going to welcome screen at all
can you access safemode?.. Try to chkdsk your hard drive under safemode. To access safemode press F8 during bootup, then goto start>run>type cmd. Then type chkdsk /r. wait until it finish then restart your laptop into normal mode.
If the problem still exist, try to repair your windows by the use of recovery disk in windows 7 or Vista, while in XP just run the CD installer of XP and chose repair.
But if you can no longer repair the operating system better to detach first your hard disk then make a backup first and re-configure your windows. Hope it helps thanks.
Sep 12, 2011 | Gateway Computers & Internet
Windows will not load stuck on welcom screen any help with this? Please and thank you
Hi Welcome to FixYa!
If you are having this kind of problem, follow the steps below:
1)Turn off the computer completely.
2)Unplug the charger from the laptop and remove the battery.
3)Press and hold down the power button for 5-10secs. (this will drain the remaining static charges inside the computer)
4)put in back the battery and plug the charger back.
5)Try now to turn on the computer and see if you will be able to pass the Windows Welcome screen.
6)If still no go, turn off the computer again.
7)Try to boot into safemode. (Turn on computer and once you press the power button, keep on tapping on F8.. You should see a screen that has Windows Advanced Boot Options. It has different options like safemode, safemode with networking, etc.)
8)Using the arrow keys, select Safemode. You should be able to login into Windows in Safemode. You might notice that the resolution is different. Don't panic, that's normal.
9)Once you are in safemode, access the System Configuration Utility tool. Open the link to know how to access it. http://vlaurie.com/computers2/Articles/msconfig.htm
10)Once you have accessed msconfig, click on the startup tab>then click on Disable all>click on apply.
11)Click on the Services tab>put a check on the box that says, Hide Microsoft services>Click disable all>click on apply and OK.
12)it will now prompt you with a restart. Restart the computer. and it will now boot back to normal mode.
13)You should be able now to access Windows. If it is successful, there are just some startup items or services that are having conflicts while Windows is trying to load up.
If you are not able to access safemode either, pretty much you have a bad hard drive or Windows could be corrupted. Try first reinstalling Windows on you computer.
Hope this could be a big help.
Jun 26, 2011 | Dell Computers & Internet
Plz forward me a link that opens facebook full site in htc p3400 using operamobile10
All you have to do is to set up your opera mini settings. you need to uncheck or uptick the "mobile view" for you to access the full site. But, you are not yet done, once you are on the Facebook site, scroll down until you reach the bottom part of the page, you simply have to click 'full site". Then, that's it.
Jun 16, 2011 | Computers & Internet
My facebook didnt open always put your internetexplorer cannot display the page
Hi there !
Facebook site upgraded their site and requires windows explorer 8 to access this site. Just download and install it to your computer. And you access your facebook with no problem.
I hope it helps you.
Jan 21, 2011 | Computers & Internet
I have minimal access to facebook proxy, what is the best proxy that can give full access to facebook?
Most of the proxy sites wont support many java scripts that runs the facebook. Still you can find these proxy sites to be the best to access facebook.
www.facebookproxy.co.uk
www.faceoxy.com
www.squidoo.com/proxyfacebook
Jun 30, 2010 | Computers & Internet
404-not found error
Yes - this seems to be an access/permissions issue, and various Windows updates seem to trigger different defaults, even if you've changed this before.
Open Explore (right click on Start)
Go to C:/Windows/Temp folder
Right click on the Temp Folder.
Choose PROPERTIES.
Choose the SECURITY tab.
Choose the EDIT button.
Make sure you have full permission (allow) for your user name.
If you are the only one using your computer, you can give full allow access for each profile listed.
Click on the APPLY button, SAVE it.
Restart your browser.
It should fix the problem.
If it does not, then check your firewall to make sure Facebook is allowed through. Facebook changes their programming constantly, so there could be some sort of thing holding it up.
I would also say the basics - clear the cache & cookies, make sure you've run a virus scan, and then reboot. But, those are the basics of computer upkeep in general. If it is mainly FB, then probably the firewall or permissions that is holding you up.
Apr 27, 2010 | Facebook Social Network
Errors while loading page from application The URL ?_fb_fromhash=97a9fc805638d548f9b377882f00310c is not valid. Please try again later. We appreciate your patience as the developers of...
Well, you might want to try this solution. (Of course, if Facebook is totally down for site maintenance, then you have to wait it out. If it isn't down for anyone but your computer, then keep reading.)
This seems to be an access/permissions issue, and various Windows updates seem to trigger different defaults, even if you've changed this before.
Go to C:/Windows/Temp folder Right click on the Temp Folder. Choose PROPERTIES. Choose the SECURITY tab. Choose the EDIT button.
If you are the only one using your computer, you can give full allow access for each profile listed. Click on the APPLY button, SAVE it. Restart your browser.
Apr 22, 2010 | Facebook Social Network
Satelite 4070 cds when I turn on I get a black screen with full page of writing and it won't let me go any further
Ok It must say :
safemode
Safe mode with command
Safemode with network vs vs vs.
Is that right?
SO run safemode, Or start windows Normally as when was the last boot was ok.
If this is not please described the text so I try to help you.
JMC
Aug 07, 2009 | Computers & Internet
How to remove virus in my PC.
Hi
Try to run the Antivirus in the Safemode
To Access the Safemode
> Restart system before windows startup up keep tap on F8 - In Advance startup options - Select Safe mode
> Run the antivirus
Apr 19, 2009 | Computers & Internet
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
