Question about Lowrance X96 200khz Fishfinder
Lowrance x96 does not function after 20 feet depth
X96 works fine when first start and near shore. When go past 20-30 feet depth the unit displays 3 feet until you return to 5-10 feet of water when it starts working propoerly again. Unit worked fine on first trip and had no issues even in 150 feet of water.
  • 4 Answers
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
Posted on May 27, 2009
X105C unit only works in very shallow water less than 10 feet. Every now and then I might get a deep water reading when idle but 99% of the time the depth display just blinks indicating not able to get a...
When my depth finder acted like this I found out it was the sender that had not done well over the winter and was giving me false readings especially when the boat was at speed. The sender and cable only cost around 30 or $40. The hard part was since I have a pontoon boat getting under the Pontoon and replacing the wire in the spring when the water was cold.
Jul 01, 2017 | Lowrance X105c Dual Frequency Sonar
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
My Lowrance X-51 is not reading the depth sitting still of running . Do I need a new transducer ?
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Jul 31, 2009 | Lowrance Boating
How do you get the fish to show up on the screen on a lowrance X96 depth finder? We just got it and there is no manual with it.
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Jul 11, 2009 | Lowrance X96 200khz Fishfinder
In lakes that are not clear I have trouble adjusting my x96.
This depends on how muddy or clear the water is. If muddy or there is a LOT of floating sediment in the water, most fishfinders will have trouble getting a good image through the dirty/brackish water. You might not be doing anything wrong in this case.
Sensitivity and grayline are your main adjustment settings, assuming you have your transducer located correctly at the right depth in relation to your hull and the waterline as well.
Does the clutter extend all the way from the surface to the bottom? If so, try reducing sensitivty... if clutter is moreso near the surface or top of the screen, then this is probably because the transducer is getting aerated water or distrubed water over it and causing the clutter and readings.
As a good rule, match the sensitivity setting tot he grayline setting. I.e. if you have sensitivity at 90%, put grayline at 90% also.
Hope that helps!
Jun 19, 2009 | Lowrance X96 200khz Fishfinder
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
Lowrance X96 200khz Fishfinder Logo
570 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
