Hobart 24 in. LXIH-3 Built-in Dishwasher
Problem for Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher
By falene79 on May 26, 2009
sitting at hot temp (174), constant steaming from unit, bottom rinse wand spinning & humming non stop? We reset prior to problem because it was not rising to temp (sitting at 106-112)
Best Solution
posted on Sep 27, 2009
Very Helpful)
kurtmorganec
Rank: Guru
Rating: 91%, 9 votes
bad thermostat or contactor
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 05, 2009
Somewhat Helpful)
paultech8226
Rank: Guru
Rating: 93%, 13 votes
You are in luck, the LXI series are easy to troubleshoot. Be carefull of the high voltages present.
If you open the top drawer to expose the control and relay boards you can see the status of everything. You will need a small magnet placed in the drawer, on the door switch in the front right corner to make it think everything is closed. Make sure the door remains closed or you will get very wet.
If the bottom rinse arm is spinning non stop, it could be the water valve has not closed, or the boster is stuck in heat mode. There are LED's on both boards to show status. If the light is on, it is active.
The LXi gives two temperature readouts, wash and rinse. If its constantly flowing water, the booster will never recover to the set point of 186. Fix the flow first and see if the temp poroblem goes away.
Golder rule of trouble shooting. If you have more than one fault, and you know how to fix one of them , do it first and then re test
Was this helpful?
Yes
No
Popular Solutions for Hobart 24 in. LXIH-3 Built-in
Questions and Unsolved Problems for Hobart 24 in. LXIH-3 Built-in
Do you recommend Hobart 24 in. LXIH-3 Built-in Dishwasher?
Answer
Answer
I have a Hobart HD-20 home dishwasher that is leaking at the bottom left corner on the final cycle.... (More)
Answer
the lxih is stuck in delime. It runs "wash" then did "rinse" x1 and then just... (More)
Answer
I cannot find a soap and rinse distributor for a Huber home under counter machine. How can I get the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 24 in. LXIH-3 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
