Question about Ducane 455 inch 2 - 3 Burner with rotisserie Grill
The burners sounds like a jet plane.
The burners also pop and go out. The Ducane grill is about 15 years old and I've never had a problem or needed service.
Please help.
Thank You,
Mr. Rawmeat
  • 420 Answers
Make sure the burners are clean, each and every little hole must be clean. It sounds as though the flame is burning near the inlet of the burner which can occur if the holes are restricted too much.
Posted on May 26, 2009
None of my igniters on my 30400043 Ducane grill will light the burners. I've had a grease fire due to the burners rusting out and replaced the burners. The insulation on the wires to the igniters has...
As I tell customers, when they ask me, "How long will this grill last?" "That depends on well you take care of it with routine maintenance and cleaning."
The wiring for the electronic ignition and the spark ignitors are replaceable. The ignitor button or the "clicker" as you called is replaceable. But all you may to do, is change the battery inside the igniter button. To help you further, i have included a link to the Owner's Manual for your grill. It will have an exploded view of the parts, which should help you identify them by part number and order them from Ducane, if you like.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
A far as the infrared burners are concerned, they blow out easily if the wind is just blowing slightly. That's why they have a thermocouple on the burner, to turn the gas off to it, when it gets blown out. When preheating an infrared burner, the hood/lid of the grill should be closed.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Ducane 30400040 Stainless Steel Grill
Install replacement burners
You've got a job ahead of you! Duncane is the only grill on the market that I know of, that requires the removal of the Control Panel to remove and/or install new burners.
Here is a link to the Owners Manual. What you need to know starts on page 21 (Annual Maintenance). Good luck.
You can download and print the manual for future reference.
Hope this helps you. Please let me know. Thanks.
May 05, 2011 | Ducane 30400040 Stainless Steel Grill
How do I remove the old burners to replace with new?
Should be as easy as removing the screws at the ends of the tubes and sliding the tubes away from you and putting the new ones in like you took out the old ones.
Apr 10, 2010 | Ducane 30400040 Stainless Steel Grill
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
How to clean a gas grill with clogged jets
You can take the burners out of the grill, and if you can get to the orifices, they will hopefully unscrew. You can use canned air and a pipe cleaner to clear any blockages. If you can't get to the jets after taking out the burners, you will have to do further disassembly of the grill. When you have the burners out you might also check for any blockage in the burner venturis.
Jan 06, 2010 | Ducane 30400040 Stainless Steel Grill
My Ducane grill is not burning at full capacity.
check the orifices they can get clog!
Dec 06, 2009 | Ducane Grilling
Cannot light new burners
I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
Ducane F7011013 FireLight II grill I am looking for a replacement burner. The one I have has rusted out. Any suggestions on where I can get one? Is there another burner that will fit in this grill? ...
I have a brand new Ducane Firelight II Camp Stove/Grill in need of a regulator/hose assembly. Would you be interested is selling me the parts from your stove? kpirish810@yahoo.com
Apr 25, 2009 | Ducane F7011013
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 455 inch 2 - 3 Burner with rotisserie Grill Logo
294 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
