Home | Akai | LCT2785TA 27 in. LCD Television | No signal
Akai LCT2785TA 27 in. LCD Television
Problem for Akai LCT2785TA 27 in. LCD Television
No signal
By fixITabc on May 26, 2009
After repairing the power supply due to only getting the red light it now powers on shows the AKAI splash screen then goes to a blue screen in "svideo" mode and a "no signal" in the upper right side. Also it shows a volume level at 0 and the 0 pulsates. I'm unable to power the t.v. on or off with the button on the t.v., I can turn it on with the remote but it will not respond to turn it off with either the remote or button. I've disconnected the button control panel on the t.v. and it responds the same. If I hold any buttons (except for the volume down) on the t.v. for 3 seconds the volume level will disappear until release it. It appears to be stuck, I can't change inputs or anything. I hook up a Svideo source and it still shows "no signal". I also tried a known working power supply without any change in t.v. operation. Any ideas?
Solution #1
posted on Oct 15, 2009
Not Rated)
rudygob
Rank: Apprentice
Rating: 75%, 1 votes
Replace the button board
The volume down switch is shorted
Still having problems
Email me @ rudygoberdhan@hotmail.com
Comments:
Oct 15, 2009
- Replace the button board
Oct 15, 2009
Oct 15, 2009
Was this helpful?
Yes
No
Popular Solutions for Akai LCT2785TA 27 in. LCD
Questions and Unsolved Problems for Akai LCT2785TA 27 in. LCD
Do you recommend Akai LCT2785TA 27 in. LCD Television?
Answer
Answer
Hi, I have an Akai LCT2785TA LCD tv approximately 2 years old. I was viewing the tv the night before... (More)
Answer
Our Akai tv will not power on and stay on. In the past we were able to unplug the tv and replug it... (More)
Answer
I try to scan for DTV channels and this tv doesn't find any. When I scan using DirecTV receiver then... (More)
Answer
tv wont come on power light is on but nothing else
Answer
My LCT2785TA TV has only one channel now. I cannot change the channel with the controls on the TV... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Akai LCT2785TA 27 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
