Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Wont print shows no cartridge or empty ink on yellow & magenta. Why cant I print in black?
    Sniper:
  • 73 Answers
Dear, when the cateridge get out of order, it disturbs the normal fucntions, you need to remove the color cateridge and check the printer with only one black cateridge to make printer work as a balck. The problem is with color cateridge, by removing it you can resolve it. The other way is to unintsall the dirver of printer and unplug it from the sytem, re-boot the system. Install the driver again, this will make the utility to show the right level of ink. Please try this, your problem will be resolved.
Best regard.
Posted on May 26, 2009
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Mar 26, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Printer wont continue printing if ONE cartridge is empty
Sorry to say this, I had a Canon Pixma and it wouldn't print unless you replaced empty cartridge, although I did have some success for a while longer by pressing OK button?
Feb 27, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Dec 31, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
81 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
