T3 code falshing on LG WM2688HWM - Washing Machines
  • 5 more comments
  • 9215 May 26, 2009
    T3Code showing up on LG WM2688HWM washer
  • 9215 May 26, 2009
    Sorry come to find out it was Te code, manufactuer stated to unplug it for a few sec and see if that reset the board, well it didn't. If you put it on a cycle it will start to fill w/water and start to spin then stop and falsh the Te code.
  • 9215 May 26, 2009
    you didn't get my last posting regarding the code is Te instead og T3
  • 9215 May 26, 2009
    LG washer WM2688HWM flashing Te code ?
  • 9215 May 26, 2009
    where is the thermistor located do you have a diagram
  • 9215 May 26, 2009
    did you get my last posting???????????
  • 9215 May 27, 2009
    Thank you very helpful
  • 3,741 Answers
TE means that the temperature sensor is faulty. TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
Often this is caused by a leak from somewhere, possibly the soap dispenser but unlikely. Fairly straightforward and not too expensive to repair.
--------------------- Quick tip:
During the wash cycle, press & hold the temperature button. This displays the current temperature of the water via the temperature sensor, this will tell you if the sensor is working or not
---------------------------- also try this  you will have  to remove the top panel of washer and disconnect all wiring clips and tubes from the off white rectangular plastic box monted in washer towards the top left. there you will see the thermostat.Then remove all the screws out of the thermostats and pull  them out and cleaned them. What you will  find  will that they all will  be scaled over probably by hard water. you   take  the rubber cap off box filled it with water and shook it up and flush it out. put back together and check out.it will mostly work if the thermostat is proper.if not then replace the thermostat.
------------------ to remove the thermister ,After pulling the lid and finding it location- you  had to do is flip washer on its back, the bottom of the washer cabinet is open and pull the thermistor out it is in rubber grommet and easily pulls out.
the thermostat and thermister are one and the same.so dont be confused in names. you can get new thermostat at  www.repairclinic.com or at  www.partselect.com
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 27, 2009
    Brigadier General:
  • 3,917 Answers
Please download the user manuals from the bellow mentioned links as the manuals do mention about error codes and their remidies.
http://uk.lge.com/index.jhtml
or here
http://gb.lgservice.com/gcsc/b2c/hpi/main?tc=o wm.command.OwmCmd
Also searched in the database for T3 problem, could not find much. Check the bellow link for all error codes and its reasons in the bellow link. Hope you got the error code correct.
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
Thank You
Posted on May 26, 2009
  • e-Guru
    e-Guru May 26, 2009
    Please refer to page 17 of 44 of the repair document pasted bellow:
    http://136.166.4.200/contents/Laundry/WM...
    heater or thermistor fault.
    The machine may have stopped in heat pause, and is waiting for the water to reach the correct temperature before advancing on. Check the heater, heater connections, thermostat connections and the connections on the timer, (looking for a burnt out terminal or wire).Check for wear of the wiring insulation allowing the bare wire to short out on the machine frame. Heater is located at bottom of drum. If testing with a multimeter, disconnect the wiring and take a resistance reading across the terminals - should be around 20 ohms. If heater is blown (broken internal heater wire) it will give an infinite resistance. There should be no continuity between the either terminal and the metal sheath of the heater - if there is, there's an internal short circuit. When removing heater, disconnect wiring, undo central mounting nut and prise it out of its rubber seal - may require some effort. Replace heater, use sealant when refitting rubber seal and ensure it is fully pushed into the recess in the backplate. Make sure the element locates into mounting bracket inside the drum.(look inside the element with a torch and you will see mounting bracket). This bracket ensures that the moving inner drum doesnt strike the element and damage it.
    Sniper:
  • 91 Answers
Is it T3 or the TE code? The TE error code means the thermistor needs to changed. You will need to call a qualified LG technician to resolve this issue.
Wait...I did find someone who asked this question previously and an LG expert answered with:
"I had this problem on my lg steamwasher wm2688hwm.
I had to remove the top panel of washer and disconnect all wiring clips and tubes from the off white rectangular plastic box monted in washer towards the top left. Then i took the screws out of the thermostats and pulled them out and cleaned them. What i found was that they had all been scaled over probably by hard water. Then i took the rubber cap off box filled it with water and shook it up and flushed it out. put back together and works just fine now."
Posted by JMHOWLETT.
I hope this is helpful to you, washers error codes can be frustrating. Let me know if there is anything else I can do by commenting back.
    Sergeant:
    Champion:
  • 219 Answers
can u please eloborate more and also is it T3 code?
  • Sandeep Gupta May 26, 2009
    i think the code u r giving is wrong.Please rechek it
  • jenny Nov 15, 2016
    I have error code t3 on my lg washer how do I get rid of it please
LG TROMM WM2688HWM no power unless i manually rotate the drum
You have to check and replace the motor capacitor. There would a starting capacitor attache to motor. You have to replace that.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 02, 2016 | LG WM2688HWM TROMM SteamWasher
Error code E0
THE CODE IS "OE" Not EO! There is NO EO error code. Go here http://www.youtube.com/watch?v=f_-bBjx46Bc
OK? All you have to do is watch the Video and there is a review trouble shoot. You probably have a bent water Inlet Line. Or it is Kinked
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Washer machine erroe code oe
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Clean and straighten the drain hose / clean the drain filter.
Jun 30, 2010 | LG WM2688HWM TROMM SteamWasher
Mold substance found in rubber ring of a front load washer WM2688HWM
comes from the powder/liquid soap use..no solutions,,sorry,, claen after use allways dry
Jun 21, 2010 | LG WM2688HWM TROMM SteamWasher
My washer has a code D3
Are you sure it's an LG? I looked up in the service manual and found nothing.
Dec 13, 2009 | LG WM2688HWM TROMM SteamWasher
How to acces the diagnostic code an a new lg tromm washer
The codes should be in the manual
au.lge.com
Go to this site and download the pdf file for your
model
Jun 13, 2009 | LG WM2688HWM TROMM SteamWasher
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Trying to wash but le comes on the screen
le code is pretaining to tne motor, overloaded ,too much soap, or bad motor .disconnect power for a minute and try agian if proble presist you'll have to have motor repaired
Dec 20, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
369 people viewed this question
Top Washing Machines Experts
