Calypso washer---the dome covering the inner wash plate has somehow come off. How do I put it back on ?
  • dbrb49 May 27, 2009
    I wasn't strong enough but thanks for the info-deb
    Novelist:
  • 151 Answers
As the inner wash plate has to be removed and readjusted .and the upper dome too has to be readjusted.the procedure is quite bit and tough if the top dome is got misallighned it needs to be opened.this procedure is bit long and time consuming.but you can do it without any technicians help
this the instruction manual.
in the manual from page number 30 its shown how to disassemble and reassemble all the parts in the unit .
click the link directly.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
this will help you.for all the problems.
thank you .please do rate the solution.thank you for using fixya.keep updated.
Posted on May 26, 2009
Remove Agitator and floor plate
Remove the agitator dome by pressing on the 4 snap ins on the bottom of the dome and wash-plate. Remove the bolts from the wash-plate and lift it out. Here is a exploded diagram of the assembly.
Jan 29, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remoce the agatator and tub from my colypso washer?
On this machine - the "agitator" is referred to as a NUNATOR or wash plate.
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa!!
Nov 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer, has debrise and clothing
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Calypso washer has eaten some clothes. I know that clothes are under the drum. Can I somehow remove it to get to the the bottom to retreive the clothes?
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Apr 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove outer washplate from. kenmore
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Jul 24, 2009 | Kenmore Washing Machines
My kenmore elite with calypso motion top load is leaving black marks on my clothes and they are getting caught between to bottom plate and the side wall, the plate is fairly new.
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Sep 28, 2008 | Kenmore Elite 21086
Whirlpool calypso washer black streaks
to all that are having a problem with these calypso washers... if you have paid for a repair then you need to check out the lawsuit... calypsosettlement.com and see if it applies to you.
but if you are getting a mark or a residue on your clothes, then look at the inner wash plate gasket, where it meets with the outer stainless steel tub. if there is a gap between the gasket and the tub then thats where the marks are coming from.
it happens alot and thats not covered by the settlement, but its not too bad to replace the inner wash plate. you need to remove the cabinet, then the tub cover and the innerwash plate dome. then 6 screws and the cover will come off.
replacing the inner wash plate will solve the stains and get you a few more years of use until you have to buy a new washer as more items may fail.
Apr 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
