Question about Uniden TRU9496 Corded / Cordless Phone
Line #1 no dial tone on base unit, incoming calls go right to voice mail
Model #TRU9496, base unit and (4)cordless phones. No dial tone on base unit Line #1. Readout on base unit and invididual phones say "Line#1 in use". Can't call out on Line #1 on base unit but can call out on individual phones. Calls coming in go right to voice mail. Line #2 has dial tone on both base unit and individual phones but still all incoming calls go to voice mail. I hope this makes sense. Taffy
  • 86 Answers
SOURCE: Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Posted on Jan 20, 2008
  • 64 Answers
SOURCE: no dial tone no incoming calls or outgoing calls
Have You Tried Replacing The Cable Connecting the Base To the Wall Jack? If Not Do That...
If that doesnt work there should be a channel button on the handset try that...If that doesnt work i would say the handset itself is bad.
Posted on Apr 03, 2009
carlsbiz
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
MATRIX_MMX
  • 209 Answers
SOURCE: Can't make outgoing calls
Hi, have you checked from your service provider that you have an outgoing service? Any number of problems could cause you to lose outgoing dialling, and some of these causes are outside of your control. In my opinion, I would first try a different phone; plug that into your line and see wether you have the same problem. If you do, I would first check your immediate surroundings to make sure that nobody has tampered with your line. Secondly, get your Telco to do a line test; they may charge a smal fee for this, but this depends on region and of course your provider. Might also be advantage too check any other connections and microfilters if you have those. If you have a broadband line, then consider unplugging your computer and router from the phone line and do the test by the main socket with just one phone. More sockets? check these one by one. This is the best way, and the most secure, may save you a lot of time and aggro in the future, and lets face it. If it is the handset, they are cheap enough to replace, but test your line first because this is more expensive and time consuming.
I hope this is the fixya for you, and best wishes in resolving this issue.
yours sincerely
oz
Posted on Feb 23, 2010
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
Had a bad electrical storm. The next day my cordless AT & T phones ( 1 base with answering machine and 1 remote phone) had no dial tone. They both ring on incoming calls but unable to connect. They...
The damage is not to the phone line it is to the phones. Unfortunately this is very common with powered phones as they are almost never kept on surge protectors and are very fragile. You will need to purchase a new base station to use with existing phones.
Apr 29, 2011 | AT&T 650530003417 Cordless Phone
No dial tone phone jack tested ok phone rings incoming call when you pic up nobody. changed battery still no dial tone or conection on incoming call
This is caused by a failed wireless signal transmitter in the base station or a failed wireless receiver in the handset, these phones are not repaired unless they are under warranty, so all you can do is replace it, this is the #1 PROBLEM WITH ALL CORDLESS PHONES.
Mar 22, 2011 | Clarity C410 Cordless Phone
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
Uniden TRU9496 Corded / Cordless Phone Logo
75 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
