Question about Acer Aspire 5520-5908 Notebook
Cant connect to my dial up provider
Im tring to connect my computer to a dial up provider and cant get past a few error codes i tryed to talk to the provider witch is msn and all they can say is there is some thing not turned on in my laptop the error codes are78 and 721
  • fougzki May 11, 2010
    Additional help.
    http://www.tiscali.co.uk/help/modem/erro...
  • Art Ellison
    Art Ellison May 11, 2010
    Tell me just how you try to connect, when the codes appear, and what else the error messages say.
Why cant I get my ggrannyglo@gmail email from the last few months altho the computer says I am connected to the internet?
you can be connected to the internet but not the e-mail server
call your service provider for help
Jan 27, 2017 | The Computers & Internet
No dial tone error when using my lg220c as a modem to connect 2 the internet
If you're talking about using a cell phone device as the modem or router so your computer can connect to the internet, just drop into your cellphone provider's store and let them show you.
May 29, 2012 | Computers & Internet
Made unsuccessful attempts to connect to the Internet using the dial-up modem. The internal modem came installed on my original PC and is a Smart Link 56k Modem. What do I do?
Can we have more information about the problem you have when attempting to connect ? The error code and message would me very useful in your case.
For example :
1. If it says the modem is already in use, go to "Network connections" or "Network and sharing center" and delete all existing dial-up connections, then create a new one based on the settings your internet provider gave you.
2. It might be a problem with the login and password. Write both in Notepad on the computer, then copy and paste the information in the required fields in the connection window.
3. It might also be a problem on the telephone line. Try another computer with dial-up modem known to work properly. If the problem repeats on that computer, the problem is on the telephone line. You will need to contact your provider to fix the problem.
May 05, 2011 | Smartlink All 56K Modems: V.92 PCI Chipset...
I bought a used pioneer deh-p7900bt, i cant use the bluetooth because of a code error, my phone recognises it but i cant connect. is there a universal code or a reset?
As an owner of the 7900 i'm assuming your talking about Error-80
If this is the one, turn the ignition on, using a pencil or similar item press the button just to the left of the eject button. this will completely reset the internal flash memory. Once it turns back on hold the dial in until you get into a setup screen. rotate the dial counterclockwise to "BT Memory"
press the dial to the right and it should come up with "reset?" now press the dial. 99% of the time it will say error but it still completes. Now turn the stereo back on and press the phone button. pair your phone to the stereo and viola you're all set.
Apr 22, 2010 | Car Audio & Video
Im trying to download weekly puzzles to my dsixl im on talk talk broadband it keeps coming up with error code 51100 can you help
Error Code: 51100 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do: Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
  • Errors ending in 0 = connection file 1
  • Errors ending in 1 = connection file 2
  • Errors ending in 2 = connection file 3
  • Errors ending in 3 = Nintendo Wi-Fi USB Connector
Mar 07, 2010 | Nintendo DS Console
Basic phone lock cannot be passed/reset/overridden....HELP
do you have a USB connector and the computer with you?
since you want to try it , here are the steps (It's your own risk)
search on the internet the software "SMARTMOTOCRACK2" or MS_TOOL crack, download it and install to your computer
once you alreadi installed and can open the software, connect your phone to it,
let it read first the phone info
then there are choices that you can make, just choose uNLOCK
that will do the booting
Goodluck
Nov 02, 2009 | Motorola Mobility RAZR V3
Cant connect to the internet
680 Error is No Dial Tone, Make sure you are trying to connect with a Ethernet port, DSL will need a Modem, In between the computer and Phone jack (Sorry if im being too basic, but i want to make sure we cover EVERYTHING) Go in to the connections and try using the Ethernet adapter. Let me know where that gets ya
Nov 24, 2008 | Compaq Armada E500 Notebook
Error Code 815
If you do not want to connect to the internet through a dial up connection. . .
Solution:
Using Windows Vista
1. Open the Control Panel
2. Select Classic View on the left
3. Open Internet Options
4. Click on Connections
5. Select "Never dial a connection"
6. Click Apply
7. Click OK
8. close all browsers and restart your computer (suggested)
May 16, 2008 | HP Pavilion dv6000z Notebook
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Acer Aspire 5520-5908 Notebook Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
