Dear Reader, I am writing in pursuit of a solution to the problem of my 30D not turning on. I have taken off the battery pack and tried with a battery alone, and still, nothing works. However, when I open the CF card "drawer" and close it again, it shows signs of loading, and is responding as usual. Any help would be much appreciated! only the LED on the SET Wheel turns on (a little darker) when i put a Battery in, nothing else doesn´t react to powerswitch or to any Button
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
after a hit of my camera 30d every thing is working perfect but thr light meter has the same problem...
(More)
after a hit of my camera 30d every thing is working perfect but thr light meter has the same problem , i will like to know were is exactly located the light sensor to beable to see if it is dislocated or loose, , any one knows were is located or what is the number of the part to locate it on the canon 30d diagram
thanks
