Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Kenmore dishwasher mod# 665.16362300 spinner falls off.
There is a spinner, part #8193768 located at the top of a Kenmore mod# 665.16362300 dishwasher. It falls off along with the retaining hub. I replaced the spinner and hub. I did not replace the top pin because the replacement parts didn't describe how to get to it.The replacement worked for about two month but it has fallen off again
jsrock516
  • 5911 Answers
SOURCE: Kenmore 16032401 Quiet Guard 4
Sorry to take so long getting back to you. Go to searspartsdirect.com and type your complete model number in the "Search by Model Number" window. Follow the links on the next page. You can also try repairclinic.com. The website offer competitive pricing with one of the other usually having the better price. The Sears website offers helpful parts diagrams. If you have any futher questions, please let me know.
NOTE: There may be a possibilty that you could have damaged the part you already replaced. It is recommended that you replace BOTH components at the same time. They are available as a SET on both websites I believe.
NOTE: Make sure your exhause ducting is clear as well before starting the unit or it will overheat and do the same thing.
Posted on May 19, 2008
SOURCE: The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
Posted on Mar 16, 2009
  • 70 Answers
SOURCE: door falls clear to bottom when opened almost got
one of the nylon rope which connects the door hinge to the door spring is broken.usually with time the rope wears out and break.it is preety easy fix. u have to pull the unit about half way out and look for ropes on lhs and rhs bottom of the unit.buy the rope kit(it comes with 2 ropes and plastic roller unit.). just see the one which is not broken and accordingly install the broken one.usually u dont have to install the new rolers unless they are broken.
Posted on Aug 26, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
SOURCE: snap on fitting no longer stays on faucett
go to www.searspartsdirect.com and you can search by your model number for the dishwasher or any other kenmore part. The schematics magnify as you mouse over them and then you can scroll down to see the matching part number. The part 3378117 is the whole hose assembly including the faucet coupler and the full length of the hoses. Notice that the part number 3378117 has been substituted with W10217197. When I Googled for "W10217197 dishwasher" there were a number of vendors selling that part including ApplianceZone.com selling it for $20 less than Sears and other vendors. Unfortunately the way the faucet coupler is crimped onto the hoses you have to replace the full length of hose [not just the coupler] but I have a problem that requires the whole hose. I've opened the cabinet up - which required a star headed driver - and from there it's just a matter of removing basic connectors inside the box.
Posted on Nov 04, 2010
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 | Dishwashers
My kenmore m # 66515829 the water jet spinner under the top basket is not spinning to clean the dishes, I have set it in a postion closed the door let it run then open and it is in the same spot. I have...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Kenmore Dishwashers
Dishes on top rack don't get washed. Water
replace the wter conduit that runs up to the top and center spinner arms,after while these plastic conduit outlets get worn by water going thru them and leak past the o-rings installed on them
Apr 15, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Water won't go to the top spinners
there is probably food stuck in the spinner,
ive had to remove the spinners on my mind one a year, and use the pressure washer on them, to get out the small chucks of food, and or plastic pieces.
Yes i know we can rinse more, but hey no one is perfect :)
Aug 21, 2009 | Kenmore Dishwashers
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
Top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Sep 07, 2008 | Dishwashers
-place top drawer
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Upper Spinner Falls off
rachir...I believe the manufacturer redesigned this spinner. You can find the part at this link http://www.repairclinic.com/0080.asp Catriver...post back.
Jan 11, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
416 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
