Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Not working Most recently, my computer doesn't detect it at all. My suspicions heightened when, upon inserting the power cord/ac adaptor, the hard drive didn't make a noise, indicating apparently it isn't spinning. I really need your help as soon as possible; the drive contains important information.
    President:
  • 2,992 Answers
The only help I can offer is to suggest trying another power adapter first. I've serviced several Maxtor external drives that lit up but wouldn't spin (just clicked), and the trouble turned out to be the power adapter was just too weak. If the adapter is okay, the trouble might be on the interface board inside the case. You would need to remove the drive from its enclosure and connect it directly to a PC power supply to check it out. If the drive itself is in fact faulty, your only option is to contact a data retrieval company to see if they can recover the data from your drive. Be warned: this is an expensive operation.
Posted on May 26, 2009
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
Lacking AC adaptor
Hello
Just recently i had the same problem just with my guitar pedal. My adapter broke and i had to make another plan.
So i was left with 2 options, either stop playing guitar or buy a new adapter, which is expensive. I then found a multiadaper. With this you can choose between AC or DC, and you have different options to which voltage you need to use. Best of all, it is not expensive at all and you an basically use it for everything which needs an adapter. You can buy this at any electronic shop
Really hope that this can help you
Sep 14, 2009 | Panasonic SDR-H18 USB Hard Drive
AC Adaptor input issues (fries cord, won't charge computer)
dear,
are you using same wall socket everytime for this job...
if yes, then check the mains there too...might be its because of that..
if all are fine in the socket then u have to check the laptop power supply section ....
rate it if issue resolves.....
Apr 17, 2009 | Computers & Internet
Problem with power cord/AC adaptor...maybe?
I would just go buy another battery charger pack. They are like 75 dollars to buy. Sounds like yours might have a short in it!
Mar 26, 2009 | HP Compaq nx6110 Notebook
Missing power cord/adaptor
You just need to go to Radio shack, and get a DC9V Adapter at 500mA and the correct polarity of (-) on the outside and (+) in the center. Original was a AHEAD AC Adapter Model ADB-0900500
Good Luck
Mar 14, 2009 | Cycling
No Power
there is a chance of battery failure
Feb 14, 2009 | Dell Inspiron 600M Notebook
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Lap top problem
    Hi
    If the AC power light is blinking, try the following steps:
    1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
    2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
    defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
    3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
    4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
    5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
    Regards
    Mike
    Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
    SimpleTech 320GB Hard Drive- unable to detect the device
    My simpletech external did the same thing. I used another AC Adapter from another External drive and Viola...it works great. I think the adapter came defective.
    Jan 01, 2008 | Computers & Internet
    Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
    533 people viewed this question
    Top Maxtor Computers & Internet Experts
    Computer Links
    Rick Arnold
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
