Question about ASUS P5GD1-VM Motherboard
Motherboard detects nothing
Building new computer.  Everything set to factory settings.  Powered by 600 watt power supply.  Motherboard comes on, fans come on, DVD comes on if not plugged into motherboard only power, floppy light comes on.  Monitor remains in power saver mode, no keyboard lights, no mouse light.  I have been swapping out keyboards, mice and monitors all day.  Moved monitor from onboard to pci and back again - no luck.  Can't get into the bios because I can't see the screen.  I don't have a PCI express video card handy but have tried a PCI video card.  I am at a loss.  Any ideas? Other than go back to an AMD board? I have built dozens of AMD's; this is the first using Intel.
  • anniegms Oct 21, 2007
    The only problem is, I only have one Intel computer/processor.  All 3 others are AMD.  May be easier to take it to my friend who has a bench and let him get it up and running.  He has a shop so am sure he probably has a spare processor to swap out and upgrade the bios.  Thanks for trying!
  • subra_manian Sep 12, 2008
    I have a PC with ASUS P5GD! - VM motherboard with 1 Gb Memory along with 120 GB HDD and DVD drive. Few hoursa after I switched off the pc, I switched on the PC too find the pc is not working. Only The onboard light in the mother board is on. Fan of SMPS not running. What can be the problem ?
    Problem Solver:
  • 5 Answers
Anniegms, I had the same problem with a new Asus board running a Dual Core Duo Quad processor. The boards BIOS was not updated to handle the Dual Core Duo yet. I had to switch processors to a P4. Use a different PC to make a BIOS update disk. Update the BIOS and switch processors back. But I had all the same symptoms of yours. However I did/do have a PCI-E XFX Fatality (Nvida) based graphics card. I would check or swap processors, it sounds like the board is waking up but not the processor. Just my thoughts.... PCdok
Posted on Oct 21, 2007
I have a Fatal1ty FP-IN9 SLI motherboard installed in the case with a 750 watt power supply. I turn on the power, and it runs the Plextor CD writer with an XP installation CD and does not boot the hard...
If there is a disk in the cd device the bios is set up to boot up from there first. So if you have a xp OS disk in there that is what will happen . Remove the disk and it should boot from the hard drive if it is properly loaded.
Sep 09, 2017 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Computer will not power up
There may be a short on the motherboard. If the power supply senses something wrong they system will not boot up - unless you bypass the On switch.
I had a friend do this but he was building a system, he put all the standoffs in the case and the ones that didn't line up with the motherboard holes shorted components - he was fine until he bypassed the on switch.
Your system is a Gateway, so unless you have a screw rolling around in there (did you install a hard drive or something???) then the problem is something component failed.
Feb 27, 2010 | Computers & Internet
No power at all. what and how to check
Unplug everything but the motherboard and front panel connections. Remove any cards (even the video card) and ram and see if the system comes up (you should hear error beeps and get lights). Install the ram next and retry if the power is up. At the point where the disappears you have found the bad component/ device. If no power lights with everything disconnected but the processor the power supply is bad or mother board is bad. The switch on the power supply is set for your line voltage correct?
Oct 24, 2009 | OCZ StealthXStream / 600-Watt / ATX /...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Q6600, psu fsp bluestorm II 500watt,250Gb SataII, 4GB Team xtreem dark PC8500... question : is it enough to support Sapphire ati HD4890? my plan is oc q6600 to 3.0Ghz..
That video card uses 190 watts peak... you want to have a power supply that far exceeds your motherboard, processor, video card, and any other components that you have in power requirements.
I believe the Q6600 is 95 watts of power peak. Your HDD might use ~10 watts give or take. Your motherboard will use some significant power.
Your DVDRW and other drives will all say how much power they use right on them. (If it shows Voltage and Current measured in V and A or volts and just multiply the volts x amps to get power used)
Assuming your motherboard might use 100 watts (just a wild *** guess) and assuming that you have plenty of case fans in the system... no I don't think 500 watts is a good idea.
Your power supply is only 80% (maybe 85%) efficient. That means it can really only put out about 400 watts of real power reliably. You are using up close to 400 watts of power with all your components running at "maximum power". So sure, you could use your current power supply for now... but as soon as you can upgrade I would recommend going with a 650 or 750 watt power supply.
I just bought this one for a system I am building:
It is overkill for the system I am building, but think of your power supply as your foundation that everything is built off of. Nothing can run properly on your computer without stable power.
You could probably go for their 650 watt version and be sitting pretty.
Apr 29, 2009 | Computers & Internet
EMachine will not turn on.
Sounds like the power supply is faulty. Power supplies are very dangerous to try and repair, even for qualified technicians. I would also suggest not trying to plug it in or turn it on until the new power supply is in place. Faulty power supplies have been known to cause motherboards to permanently malfunction. Note: researching your issue, I came across several forum posts with complaints about emachines and their power supplies. The best way to solve this problem is to purchase a new power supply. If shopping online, and are two places that specialize in PC hardware. A 400-watt power supply would probably more than do the trick for you. The cheapest one I found was $18.00. Make sure the power supply is compatible with your motherboard before you buy.
Dec 27, 2008 | E-Machines eMachines Desktop PC
GA-EP35-DS3R won't POST - Core Duo E8400 / 2GB Crucial 8500 DDR2
remove your cpu core voltage connector and power on if power on still so 100% your vrm circuit mosfet sort
Mar 30, 2008 | Intel Motherboard
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Mach speed motherboard problem
I had the same problem once. I took it to CompUSA to have them diagnose the problem, and they said I fried the motherboard or CPU. The fans turn on just because your power supply is on.
Jan 14, 2007 | Mach Speed P4M800 (890552603480)...
ASUS P5GD1-VM Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
