Question about Venturer RTS2628 System
Every time i put in a vcr tape the vcr turns off what can i do?
Venturer dvd/vcr combo home theater system
    President:
  • 2,992 Answers
This is probably happening because the tape loading isn't completing within the required time after you insert a tape. Either the tape isn't seating properly in the machine or something is interfering with the loading. This might be due to the tape itself, but since you've said this happens every time, that's unlikely. There may be something inside, like a piece from an old cassette. The VCR mechanism may be out of timing. There are plastic gears that need to mesh properly so that all the parts move at the right times, and these can get knocked out of sync. Or there might be an electronic problem in the power or loading circuits. There's not much you could do other than take the cover off to see if there's an obvious obstruction. Beyond that, this needs to go to someone for service, or it's time for a replacement. Given the low cost of these combo units today, replacement is the usual "fix".
Posted on May 26, 2009
I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Nov 14, 2009 | Zenith XBS448 System
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Aug 28, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
SONY VCR: Keeps ejecting video tape
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
I don't have the code to the remote
www.rockabilly.net/files/manuals/URC-3220.pdf
Nov 17, 2008 | Audiovox 150W DVD Home Theater System -...
Remote code
I've just been searching & found 745 Just off to see if it works!!
Jul 21, 2008 | Venturer STS-35S System
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Venturer RTS2628 System Logo
104 people viewed this question
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
