Question about Samsung SCX-4016 Laser Printer
Samsung scx4016/xaa paper jam message 1
Message paper jam1
  • 152 Answers
Open backside of printer and look foe any misplaced parts inside...
Posted on May 27, 2009
  • ihavsolution
    ihavsolution May 27, 2009
    open backside of printer and look foe any misplaced parts inside...
Samsung clx-3150 paper jam. it will only feed 20wt paper from bottom tray. anything else stops and i get a paper jam 0 error message
Check the specs operators manual or go to the Samsung web site look up the specs for your machine. The weight of your paper may be greater then the machine can handle.
Nov 17, 2015 | Samsung Office Equipment & Supplies
Why it has error:paper jam1 ?
Paper jam 1 error means paper has been picked up and has not reached fuser paper sensor in a fixed time .
check for any hinderance under the toner cartrdige
or bad pikup assly
Jul 07, 2015 | Samsung Office Equipment & Supplies
Samsung scx 4300 error paper jam1 install toner
Sir
there is a sensor lever at middle of the engine base, under the toner cart. when the cart inserted it has to pushed half and other half is for paper jam-1 error.
Pl. check the lever-check the smps photo interrupter-check the mech alignment of the lever- also check the cart hold lever(left-right) pressure (found on top of the engine base).
Thanks.
Dec 19, 2014 | Samsung SCX Office Equipment & Supplies
The paper keeps jamming in our Samsung laser printer 660 nd. We bought heavier paper for a laser printer but it still jams.
The ideal paper is around 80 GSM (gm2) if you are having problems with a BRAND NEW REAM of standard copy paper then your printer will need service.
paper that is thicker/heavier than this can actually cause more jams and problems and show worn out rollers earlier
These printers only tend to jam at the entry (pickup) near the base of the printer or in the fuser unit (hot area near the top)
if you are getting jams in multi page documents, have a look at which area the most crumpled piece of paper is in before you try and remove it.
the pick up rollers and separation pads are relatively cheap but the fuser units can be a bit pricey.
CLP 660ND CLP 660ND XAA Support SAMSUNG Canada
Sep 29, 2014 | Samsung CLP-660ND - - colour - laser -...
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung scx-4521f paper jam 1 error
As Roipatrick said, for Paper Jam 1 the location of the Jam is In the fuser area or around the toner cartridge. I download the service manual from www.elektroda.pl/rtvforum/download.php?id=362035 and it suggested:
1. If the recording paper is jammed in front of or inside
the fuser. -> 1. Replace the SMPS.
2. If the recording paper is stuck in the discharge roller
and the fuser just after passing through the Actuator-
Feed, Feed Actuator may be defective. ->
2. Reassemble the Actuator-Feed and Spring-Actuator
if the returning is bad.
I found if I push the paper a little bit when it goes in, it can print, so I conclude neither is correct, it is pick-up sponge needs to be replaced. It will cost about $15 parts + shipping from http://www.partstore.com/Part/Samsung/Samsung/SCX4521F/Samsung/Samsung/JC7300211A/New.aspx
So I tight a rubber bend around the roller as showed in the picture and I am printing now. :-)
Nov 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Error message paper jam1 on my samsung scx4016/xaa laser print
check paper guides also check if small pieces of paper are stock inside the printer from previous jams also check the sensors
May 26, 2009 | Office Equipment & Supplies
Panasonic DP 4530
E4- 02 Paper Jam 1. Paper Jam in Fuser Unit.
2. Paper Exit Sensor 1 or 2 is disconnected.
3. Paper Exit Sensor 1 or 2 is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
Oct 19, 2008 | Panasonic Workio DP-4530 Copier
Samsung SCX-4016 Laser Printer Logo
103 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
