Question about Hotpoint Aquarius WF220 Front Load Washer
Flashing lights and trips the electric
Hi, We have a hotpoint aquarius wf250 washing machine. Its now about 5 years old so im hoping its not dead and its a problem which can be fixed! Basically its always worked fine until about a month ago. It started by washing (on all cycles it does this) the clothes but when it got to the spin cycle is started to spin but then just stopped and the lights started flashing and i couldnt turn it on/off only by the plug, but now when it gets to spin it starts it then after about 10 seconds of fast spin it trips all my electric downstairs and the fuse box wont let me switch back on for about half an hour. If i try to re-run the cycle or try on ANY other cycle it just does the same! My husband has taken out the 'ping pong' ball in the back and cleaned it all out but still the same he has also leveled it and still the same. I have 2 young children so we are urgently hoping it can be fixed without paying out in these hard financial times! I would be SO grateful for ANY advice/help. Thankyou in anticipation!!
    Novelist:
  • 145 Answers
Are you around when the breaker trips? It almost seems as though an electrical connection is getting wet. Especially if it won't let you reset the breaker. Another reason for not letting you reset the breaker could be an overload that tripped but that to me would be within the machine, it shouldn't trip at the panel. You get pull the machine apart and check for these things. Look for and wetness or wire connections being crossed, anything like that. Something at the spin cycle is shorting out and tripping out your breaker. Also is your dryer circuit properly sized (30AMP Breaker with 10/3 wire)?
Posted on Apr 29, 2010
  • 1 more comment
  • ElectricMan
    ElectricMan Apr 29, 2010
    Sorry about the last comment- its not a dryer circuit but a washer circuit-20AMP 10/2 Wire
  • ElectricMan
    Sorry not a dryer circuit, a washer circuit 20AMP 10/2 wire
  • ElectricMan
    Note: Sorry I meant is you washer circuit properly sized-20AMP 12/2 wire
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Drum won't spin
A couple of possibilities,there is something fast in the drum,or the main drum bearings have seized up.
If it is the bearings, and it is under 5 tears old, then you should be able to get it done under your 5 year parts guarantee., you just pay for labour and call out, a much sheaper solution than buying a new washer.
You really need to determine what has caused it to jam up.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
299 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
