Question about Craftsman 8.0 amp Reciprocating Saw
Reciprocating saw-snapped blade-cannot be removed
I borrowed a neighbors reciprocating saw,a Craftsman 6.5 amp model #900.275020, to cut apart a wooden swingset. The blade became worn and I tried to replace it but couldn't remove the blade even when the hex-head screw used to lock in the blade was completely removed. The neighbor was also stumped. Further attempts at removal eventually led to the blade snapping at the base where it locks in leaving the remainder of the blade still lodged in the locking mechanism. The remaining piece of the blade moves freely within the locking mechnasim. It appears that the small nub in the locking mechanism which goes through the small hole on the blade, thus locking it in, does not retract far enough for the blade to come out even with the hex-head screw completely removed. I had no problem replacing blades the prior day. Any ideas how to remove the "blade stump"as I really don't want to have to buy a new saw for the neighbor.
Many Thanks,
Jim
  • jamesrphl May 27, 2009
    Thank you very much for the quick response. I will give this a shot first thing in the morning and let you know the outcome.
    Again, many thanks.
  • Anonymous Mar 20, 2014
    I did some cutting jobs yesterday. I need to continue with the job today. but I wasn't able to insert the saw blade into the blade clamp. it looks like something inside the blade clamp blocking the saw blade? I don't know what happened. It is a new saw which i used only once. I wonder who can give me some advice.
    thanks.
  • 2,176 Answers
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
How do I remove the nose piece to repair the reciprocating shaft.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
May 12, 2010 | Craftsman 8 amp Reciprocating Saw with...
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Mar 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
How do you install the blade in the craftsman recipricating saw model 320
You need a allen wrench to remove the blade and to reinsall it look at the base of the blade and you will see an allen wrench. If there is no allen wrench then you must pull down on the clap assembly to release the blade. If you still can't figure it out here is sears web site where you can get help for it if you need a picuter.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128394&sid=PSx20071217x00001a
Sep 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
Boot on the saw.
You are probably wanting to repair/replace the blade holding assembly. The boot does come off with persistence. You will have to remove the foot piece first (two screws). Try using long thin screwdrivers as shoe horns and be persistent. I agree that it is a poor design. Why the new improved blade lock assembly I'll never know. The nib breaks off that fits into the hole in the blade and then there is nothing to hold the blade. If all else fails to get the boot off you can cut it and order another boot. Remarkably, the boot isn't that expense. Unless you feel you can make a replacement pin you'll have to order the entire blade lock assembly and it cost about $20. I had the reciprocating saw for a tear before I used it and the holder broke on it first outing! Being loyal to Craftsman in the past, I hate to admit that these days many of the power tools are cheaply made Chinese junk. My advice, don't spend much to repair, cut your losses and buy DeWalt, Skill, etc. Hope this helps.
Jul 06, 2009 | Craftsman 8.0 amp Reciprocating Saw
I need instructions on removing the front housing so I can replace the Blade Set on my 8.5 amp Professional reciprocating saw Model 172.267700. I have the replacement part, I just don't want to take it...
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
Mar 23, 2009 | Craftsman 8.0 amp Reciprocating Saw
Craftsman 8.0 amp Reciprocating Saw Logo
703 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
