I cannot chnge the boot sequence to the cd drive on an older computer. The BIOS only shows C and A.
  • 1 more comment
  • ptgroves May 26, 2009
    I cannot change the boot sequence on an older computer from A or C to the CD drive. The computer is several years old running Windows 95.
  • ptgroves May 27, 2009
    I cannot boot from the cd dive. The drive works perfectly well in all other modes, but I can't change the bios to boot from it. The computer is a Compudyne from the early nineties running Windows 95. I wish to donate the computer to charity thus, I need to clean the hard drive.
    Refer to my previous statements/questions I can change the boot options between A&C but, I cannot shift it to boot from D which is the cd drive.
  • 272 Answers
Unless the cd rom is detected by bios, it wont show on computer. May be there is a boot sequence problem. make sure you have Hadrdisk on primary mode with jumper settings, and cd rom as the slave. Instructions should be printed on the harddisk and cd rom cover.
Try removing / disableing floppy drive.
try removing cmos battery to make sure any mistaken setting is causing this.
Please lat me know the update or the step , you can not do.
Posted on May 27, 2009
    President:
  • 1,383 Answers
Ok
when u power up the computer press "del" key then u got bios setup.
Then go to boot sequence then select c ..
then press "page up and down key so u cna set it .
  • kishor
    kishor May 27, 2009
    first check in bios your cd rom is detected and if it is disable enable it in bios.
  • 432 Answers
Ensure the jumpers on the cd drive are set correctly and you need to ensure that the bios is detecting the cd drive - if not then try the cd drive on another computer and make sure that it actually works if so have you got a second CD drive to use ?
Also the power supply - is it powerful enough to power the cd drive, the hard drive etc ?
Also have you got the CD drive and hard drive connected the correct way around on the IDE cable ?
Posted on May 26, 2009
  • 3,230 Answers
You can change these setting by using page up and page down key.
Better if you tell me how old is the computer?
Thanks
regard
all-guru
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Will not reboot
did u by chance change any settings in the bios.... if yes please change the settings.... if u donno hw to chnge the bios settings... please ask me...
Jun 07, 2008 | Compaq Presario 5000 PC Desktop
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
What can I do to fix this problem, my gr 500 is telling me to reboot and select proper device or insert boot media in selected boot device
You need to go into your Bios or System Setup and change the boot order or boot sequence. It sounds like you might be trying to boot from a Network or Lan. It could be that you are trying to boot from the CD drive but instead of having a operating system disc in the drive you might have a movie or music cd in the drive.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Gateway 500GR PC Desktop
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
Sep 19, 2010 | Computers & Internet
How do I Access BIOS screen in a IBM PII-6862-84U?
As the computer boots press the DEL key to access BIOS
note: some systems you must press F2 or Esc
In BIOS under the BOOT tab options change the Boot order so that the CD drive is First
Select EXIT and Save Changes to reboot
note: make sure the CD is in the drive BEFORE you reboot!
(it sounds obvious but a lot of people forget)
If the CD is bootable it will start its own boot sequence.
Feb 21, 2009 | IBM I System Board (61H2600) Motherboard
Can't change the boot sequence
can you see the cd rom on the devices installed list as if its not showing up it will not let you change the boot sequence. also to revert to factory settings you need to remove the bios battery hand leave out for a few minutes, then put back in on first boot it will ask for the settings to be set.
Jul 29, 2017 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
Lenovo C100 will not boot to bootable CD
Hello brush71, it most likely is.
I suggest going to BIOS and trying to enable the cd drive.
If not possible, perhaps there is a hardware failure.
As you've described a problem with the Hard-Drive as well, I would suggest, if warranty is still applicable, to turn to your nearest Lenovo lab and have the computer fixed.
Jul 11, 2008 | Lenovo 3000 C100 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
