Question about GE DBXR463EDWW Electric Dryer
Front panel not fitting properly
Ok this is my third attempt to post this but for some reason it doesn't appear to be showing up so if I am just missing it I apologise for it. I took the front panel off the dryer to replace the slides now I cant get the bottom of the panel to line up when I try to put it back. I dont see any locations for screws and since it is a used dryer dont know if any were missing. I got the two screws that go into the top back inplace but the bottom keeps sticking out. Do I need to use the foot brackets to hold it in place and if so how do they need to be lined up?
    President:
  • 1,136 Answers
HI, This model does not have screws at the bottom. There should be small tabs that the front locks on the front frame.
Slide the front panel bottom against the cabinet and then push the top of the front panel against the drum. I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 26, 2009
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
Red lights flashing back and forth
Just a small but very important question. Is the CD/DVD tray closed?
This may cause flashing lights.
This picture shows the tray (ref. Epson troubleshooting guide)
Thanks,
Lolita
Apr 17, 2008 | Epson Stylus Photo R220 InkJet Printer
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Dishwasher drain pump continues to run constantly and does not progress onto a wash cycle. I've unplugged, pulled the unit out and removed the LH panel. Taken off the side tank and the lower mounted...
You have provided a very detailed explanation of the problem. You will have to check if the spring in the float is ok. May need to replace it. Cheick this.
Jun 24, 2011 | Neff 24 in. S5457X0GB Built-in Dishwasher
I have a vsx92 that worked great up till my wife disconnected the hdmi cables to swap satellite to cable. Video runs through hdmi to the projector. I do hear audio, all cables are correct but I get no...
We had a similar problem, but was with the audio side. You can attempt the system reset like this;
Use this procedure to reset all the receiver's settings to
the factory default. Use the front panel controls to do this.
Set MULTI-ZONE to OFF.
1 Switch the receiver into standby.
2 While holding down HOME MENU on the front
panel, press ? STANDBY/ON.
The display shows RESET ? NO ?.
3 Press ENTER on the front panel.
4 Select 'RESET' using ?/?, then press ENTER on
the front panel.
The display shows RESET? OK.
5 Press ENTER to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
Hope this helps. I switched to Onkyo for my receiver.
Feb 08, 2011 | Pioneer Audio Players & Recorders
I have a John Lewis combination microwave which I believe is made by panasonic. The microwave is brand new and I get a flashing "ErC" message at random on the front panel. Do you know the reason. This is...
I have exactly the same problem with 2 of the JLBICO2 microwave ovens straight out of the box. With the first oven, the service agent who looked at it thought it might be a faulty sensor and recommended replacing this together with the PCU. John Lewis have replaced the first oven and are in the process of replacing the second unit within a couple of days. Hopefully the third time will solve this issue.
Oct 23, 2010 | Panasonic Microwave Ovens
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Hi, My Whirlpool AWZ541 condensing tumble dryer is not heating..the other functions appear ok. The two thermostats on the heating element have been checked and are working. It was suggested that a third...
I identified the part on an online spares company and rechecked behind the lower front cover. Only the rear side of the stat was exposed,but it matched the image. I removed the part and found it to be the same stat.
May 16, 2009 | Whirlpool Dryers
Washing machine will not spin dry but washes properly
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Nov 28, 2008 | Maytag SAV365ZAWW 3.3 cu.ft.
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
GE DBXR463EDWW Electric Dryer Logo
80 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
