Question about Canon PowerShot SD600 Digital Camera
ERROR OBJ I HAVE A POWERSHOT SD600 ERROR OBJ RESTART CAMERA BEEPS 5 TIMES AND THAT MESSAGE APEARS AND THEN GOES OFF HELP THANKS
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SOURCE: Problem with canon powershot SD1000
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty , or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these Canon repair instructions useful and have managed to solve the E18 problem, write us about how you did it. We're looking forward to your emails. Also, please use the links bellow to bookmark us on Del.icio.us and Furl.
Bookmark This Page on: Del.Icio.Us / Furl
Posted on Feb 29, 2008
  • 9 Answers
SOURCE: Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Posted on Mar 08, 2008
darntoothysa
  • 489 Answers
SOURCE: Canon Powershot SD600 (elph) won't
Hi
What you are seeing is a generic stuck lens error message:
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help!
Good luck from
Darntoothysam com
Thomas
Posted on Oct 13, 2008
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
rajak2009
  • 527 Answers
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Posted on Aug 07, 2009
When I turn on the camera it beeps and an error that reads lens error, restart camera appears and turns off. How do I fix this problem?
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Mar 31, 2010 | Canon PowerShot SD600 Digital Camera
Camera states Lens Error, Restart Camera
i think ur camera dropped, u try ur local repairer repairable
Mar 24, 2008 | Canon PowerShot SD600 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
117 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
