Question about Remington Electric Chain Saw
How do I get chain back on saw? And why does it keep coming off?
The saw works well for a while then the chain jumps off the saw. Got the saw from my brother-in-law and I don't have an owner's manual.
  • 188 Answers
Here is a link to instructions on installation of a chain... http://12.153.20.74/manuals/113556-01A.pdf.
Make sure that the chain has been properly tensioned. Sometimes if the guide bar nuts are not tighted securely the bar will notremain in adjustment. Verify that the guide bar bolts are hand tightened plus one full turn with a wrench. If it is has been properly tensioned, the sprocket cover tab (located on the round part of the sprocket cover) may not be inserted into the saw body tab slot. If you are still having problems you just may need a new chain. I suggest that you contact Master Parts at 800-446-1446 or online at www.masterparts.net. If you have the model number they may be able to help you with the owner's manual for your unit also. I hope this helps!
Posted on May 26, 2009
  • 420 Answers
The chain must be adjusted so that pulling up on the chain you cannot see more than three guides. If the saw is really old you should invest in a new bar, chain and it its a gas model a new clutch.
Sears 18 42cc chain saw blade keeps coming lose
I have found that the number one reason for a loose chain is from stretching, and that comes from heat or clearing small brush.
Heat being that it is not oiling properly and wears quicker, and the small brush answer (cutting lots of 1/2 in Buckthorn) tends to jerk the chain and manually stretches rather than a steady cut in a log which tends to be smoother.
With that said, yours might be something else. If I can ask a few question... When the saw was purchased, did you install the bar and chain? Second your level of experience - and is this your first saw. What I need to rule out is that the bar could be on wrong.
This saw was more than likely built by Poulan and it should have 2 nuts holding the bar. Does the bar loosen up? If the answer is no you might have a bar that is miss matched to the chain. What that means is that the chains "drivers", the tooth that is down in the bar could be a .050 and the bar could be a .063, hence the chain wobbles more that it should and might be more prone to jumping off.
Solution: Replace bar and chain and make sure they are a matched, lastly, always cut with a sharp chain.
Good luck,
kj
Aug 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Chain keeps coming off my electric 15 foot reach saw
It may be too tight or too loose.Adjust your chain tension.You want to be able to pull the chain about 1 inch from the bar.Should the problem persist.Check the blade for any bent parts.And inspect the chain for bent teeth.A chain will behave this way if it is very worn.If you have had the saw for more than one year and you have had a fair amount of use,just go a head and replace the chain.
May 16, 2011 | Garden
Chainsaw Chain Keeps Coming Loose I bought a brand new husky saw 235 and the chain keeps coming loose its about an inch under the bar after bucks up 3-5 logs in a row, the oiler is working but im not sure...
No problem.Is because the chain get streched.So open the side of the chain saw where there is the adjust bolt.The chain plate holder has a groove long enough to adjust the chain.But do not do it too tight.When adjusting try to test it without power,just by move the chain with hands.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 16, 2010 | Husqvarna Garden
The carriage comes off and makes a grinding noise when using the extension plates.it does'nt move smoothly over the bed or needles
My Chainsaw's Engine Does Not Start: If the engine will start at all, you might have a bad starter switch. Check to see that all connections to the starter switch are secure. Is the power cord cut or broken? Check to make sure that you have a proper power line connection. If all checks out except for the switch, go ahead and replace it. You may want to consider whether you are using the appropriate fuel mixture.
My Chainsaw Smokes: If there is smoke coming from the chain, it could be an indication that there is not enough lubrication. Without the proper lubrication, the chain and chain bar can become seriously damaged. Make sure there is oil in the reservoir. When you start the saw, the automatic oil pump should lubricate the chain and bar. To see if this is a problem, hold the saw tip over a light-colored surface, hit the throttle and look for oil spatters on the chain bar. If you see no oil splatters, turn the saw off. Remove the chain guide bar and see if the oil discharge slots are clogged with sawdust. Clean out the sawdust and restart the saw to check lubrication again.
The Chain Skips or Jumps: If the chain skips or jumps during operation, check the engine drive sprocket to make sure it is not worn. If you have a worn sprocket it will not allow the chain to sit properly. Also, check to make sure the chain tension is set correctly. Setting the chain tension is a part of continuous operation. However, a dull or damaged chain may also cause the skipping and jumping.
My Chainsaw Isn't Cutting Properly: If the saw cuts at the wrong angle or shoots out a lot of sawdust, you probably need to sharpen the chain. A dull chain can be very dangerous. It can cause a kickback or chain jump that might break the chain and release pieces that could harm to the operator. If your chain is very shiny, you need to examine each cutter for damage. Use a file to sharpen the cutters.
The Chain Continues to Move or Stops: If the chain continues to move while the engine idles then you should check to make sure the idle is not set too high. If it stops while cutting, see if the brake is engaged.
My Chainsaw Loses Power: If the saw loses power while operating, check to make sure all electrical connections are secure. Any break in current may cause the saw to decrease in power, stall or shut down altogether.
How to Sharpen Your Chainsaw: Once you feel the chainsaw start to "grab" or stop with more frequency, shut the machine down and begin sharpening procedures:
1. Find a good, flat surface to place the chainsaw on (clamping the saw in a vice for stability would be optimal). 2. Make sure that you have a sharpening file that matches the size of the teeth on your chain. 3. Next, you'll want to make sure the chain is clean and clear of any debris so that nothing interferes with the file or sharpening device. You should have some kind of degreasing detergent at the ready so that you can wipe the chain down and during the cleaning and debris-removal process, make sure there are no damaged or broken teeth on the chain. 4. Before sharpening, take a piece of chalk, a pencil, a crayon, etc., and mark the tooth on the chain where you begin...so you know where to end. 5. At this point, you're ready to start sharpening. Find the groove between the teeth (the little notch in front of the tooth...your file should fit right into it) and give about 3-5 good swipes of your file (if you have a good, sharp file, this should be sufficient). Make sure you use the same amount of swipes for every notch/groove so that you keep everything even. Also, try to use the same angle with each swipe; this will contribute to a smoother performance by your chainsaw. 6. Repeat this process one at a time until you have come back around to the tooth where you began. 7. Then, after one side is done, turn the saw around and repeat the process. Again, remember to use the same amount of swipes with the file every time, and try to keep the same angle; uniformity/consistency within the teeth of the chain is very important for evenness and smoothness. As a general rule, after about 12-or-so times sharpening, you will want to bring the chain into a power tool repair shop or a place that does chainsaw repair, for some professional sharpening. The pros will be able to grind the chain back into shape and get the angles perfect.
Oct 05, 2010 | Garden
My 18 Inch chain saw will not keep oiling the Chain, I had it worked on and He said it was plugged. How do you unplug it with out taking it all apart. Is there a spot to blow air through. the Preacher..
Remove the chain bar and look just below the bolts holding it in place. You'll see a small hole where the chain bar oil pump pushes out oil. Make sure this hole is clear then run the saw without the bar on.
Be CAREFUL of fingers!
You should see oil coming out of that hole. If not, you may need more serious work done with the saw (chain bar pump replacement).
Sep 02, 2010 | Poulan PP4218AV 18" Chain Saw
No oil being fed to bar
Yes as it helps keep a loose chain from jumping into the case side. Remove the bar and chain, then clean the side port area. Start the engine--it should ooze out oil from the case side port. If nothing, inspect the oil pump, lines, and tank filter. Once oil comes out, clean the drive end of the bar oil-passages--especially, the two small channels that feed oil from the large holes out to the chain groove on either side of the bar. Clean the entire groove and check the sprocket tip for free operation. When assembled, check for proper oiling by holding the bar tip near a piece of cardboard and running the saw at speed for a few moments--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Jun 18, 2010 | Husqvarna Chain Saw 20" Bar
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
Nov 12, 2009 | Remington Electric Chain Saw
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
455 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
