Question about Akai PDP4225M 42 in. Plasma Television
Green Blotches and Bars
I just purchased the 42" Plasma PDP4225M and hooked it up correctly (using HDMI cable from my HD Cable Box and component cables from my DVD player). The picture is terrible from both the DVD and Cable has green tinted lines and blotches all over the picture. When the screen goes black (like the split second when a program goes to commerical), you can see the green horizontal bars going across the entire screen all the way up and down the screen. Help!
  • 9 more comments
  • Medford Nov 17, 2007
    have have the same problem with my Akai 42 inch garbage TV. The worse buy ever. If their a solution please let me know.
    Thanks Dave
  • solanodcs Nov 25, 2007
    Same problem but dont have it hooked up with a hdmi cable...
    but a av component cable(red,yellow,white) and instead of green its red....
  • robmx Nov 28, 2007
    Same problem, green lines and pixels in any black area.
  • Anonymous Dec 04, 2007
    Mt tv is doing the same thing and its only been hooked up for 2 months.
  • Techrider Dec 06, 2007
    Same problem, and I can tell it has nothing to do with the signal input; when I remove all signal input the same green splotchy background becomes prominent.
    It is my guess that this problem exists at the first tier signal processing area, because when I first start up the TV and teh AKAI splash screen comes up, it is a nice clear blue.
    This problem only exhibited itself about 1 month after I received the TV, before that everything was fine. Now I am looking for warranty support.
  • Ngg71 Dec 07, 2007
    Same same exact issue ... approx 2 months
    after installing. Blueish and greenish patterned lines accross the
    screen. seems to diminish a little bit as the TV warms up .. approx 40
    minutes. I play a lot of video games... should that be a cause?
  • mrchris Mar 17, 2008
    Same problem here, I have the PDP4225M, purchased around 2 years ago. When screen is black or dark I can see green hortizontal bars .... sometimes problem goes away. Happens with DVD and cable box so I know it's the TV. Also tried different TV inputs like HDMI and component input but still persists.
  • Anonymous Apr 12, 2008
    Horizontal green bar on left side of akai 42 in., need solution
  • tomytodd Jun 18, 2008
    I have the Akai 5016 Plasma...50". Same issue. I disconnected first the DVD, worked ok for awhile, thought maybe the receiver (Yamaha THX) had burned the mother board...nope..called cable out and signal from cable is great and strong and it is definitely the TV which is more than a year outside of the to better technology>>>
  • cclupo Dec 17, 2008
    I have tried everything to get rid of the green bars and blothes and they still appear, this just started several days ago.
  • altoid143 Jan 06, 2009
    The sound comes on but my TV picture keeps jumping around with bars going though it. My cable company said its definately the TV. This is what I get for not getting a SONY!
I turn the tv on and the tint is off and I can't get it fixed. A friend told me it could be my vidoe card. Is that true?
Thanks Rob
Posted on Nov 08, 2009
I found the exact same issue...unhokked the composite board, problem went all away....had the same heat damage(looked like the board glazing was distorted), and everything is fine now. about 6 months since I fixed mine....local repair guys are clueless....
Posted on May 15, 2008
I have determined that mine had a problem with the composite input board. I was able to unhook the connections to this board inside the TV, after Akai, and the local repair guys couldn't figure it out....
The problem hasn't come back in a while, and since my setup is all HDMI/Component ins, I didn't affect me at all.
It looked like there was slight heat damage to the board, but not enough that it was caused by a design flaw, more like a manufacturing "accident".
Posted on Feb 24, 2008
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Hdmi connection
the vista mometer sounds like it won't concieve
Jun 23, 2008 | Akai PDP4225M 42 in. Plasma Television
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Dec 04, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
How to hook up to cable television
you will need a component or hdmi cable/satellite tuner for this tv.
Nov 17, 2007 | Akai PDP4225M 42 in. Plasma Television
Picture, No Sound from HDTV Box
Apr 20, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Akai PDP4225M 42 in. Plasma Television Logo
327 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
