Wiring old condenser to new unit - Heating & Cooling
  • Jaco
    Jaco May 11, 2010
    What make condenser do you have, is it compatible with the evaporator?
    Guru:
  • 1,524 Answers
This would be a total waste as it would not be energy wise.
Posted on May 26, 2009
We recently replaced an old window unit with a westpointe a/c mwk-08 unit. The old unit was dripping water in the house but the new unit doesn't seem to be dripping any water? Could this possible be a...
If the old unit was dripping condensate into the house, it was installed incorrectly. The replacement unit may have been installed correctly so the condensate drains outside.
Oct 04, 2012 | Heating & Cooling
My old motor on my central air unit has 4 wires and my new motor has 5 wires. wich brown wire do I use and what do I do with the extra one
There should be a wiring diagram on the side of the motor. Usually when you have two brown wires they connect to the terminals on the capacitor.
May 05, 2012 | Emerson Condenser Fan Motor 1/6 Hp 230v...
I installed a new fan motor condenser in my air unit outside and I bought a new capacitor but it looks different than my old one in that my old one has three points of connection and the new one just two....
Look at the microfarad rating on the old capacitor and the new capacitor. Many are dual capacitors in one housing. The lower rating on your old capacitor is for the outdoor fan motor and the higher is for your compressor. It sounds to me like you have been sold a single capacitor when your unit had a dual capacitor originally.
Aug 03, 2011 | Heating & Cooling
I have a blown BDP 7.5 ton Condsor unit. The old unit is R22. I want to replace it with a new BDP which has R410A. Question: I am being told that If I flush my old R22 Air Handler Coil & install a TXC...
I've done what you are describing - "however" you could void the warranty on the new condenser - by not having 'matching' coils (inside/outside). I would do some serious checking with whoever you are buying the new condenser from.
Note: I would (if possible) go back with a R-22 condenser unit (price is about the same), and you would not have any 'warranty or matching issues' going on.
Jun 03, 2011 | Heating & Cooling
Replaced condenser and had health problems. Now
Hi Bill, I am sorry you became ill from this or anything else. On a condenser, did you change out the condenser coil as in removing the freon and cutting it out, or did you remove the complete unit on top, compressor and all? If you changed out the complete unit on top, the wiring should be fairly easy to connect. Take your power in which would be 220 volts from your power source. More then likely, you will have 2- black hot wires in and a ground, either bare copper or green which grounds to the new unit case. You will have 2- new wires from the new condenser , red and black or different colors, it will not matter as each line will be 120 volts, these will be the load wires to the new unit. Connect 1- wire to one coming in, either one, and do the same to the other wire. Secure the ground and you are set. If this is what you are doing or want to do, this is the way. Once you get power to the new unit, the controls will do the rest for you. Just turn it on inside and you will be up and running. Keep me posted.
Sincerely,
Shastalaker7
Dec 03, 2009 | Coleman Mach III Air Conditioner
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
I have a intertherm model 9007590 AC unit. The condensing unit was changed to a unit that has a common wire and a y terminal and the old condenser unit had three wires at condensing unit. I can't get it to...
the unit with3 wires was set up as a dual transformer the new unit is single transformer system. it needs to be rewired at thermostat,furnace,and ac
Jun 27, 2009 | Heating & Cooling
How to wire a capacitor to a condencing unit
I can help you:
1: Put a Piece of Tape on each wire. write #1 #2 #3 etc
2: do the same on the capacitor.
3: Remove Wires with insulated needle nose pliers, and take a Insulated Screwdriver and Cross it over the Terminals on the Capacitor. Its safe, it just Discharges it.
4 Remove and go to lowes or home depot and get a new one.
5:Note the "RED" dot on the old Capacitor.make sure that you hook the same wire on the new cap.
6: Install New Capacitor and, your ready to go.
Make sure you pull out the "Service Disconnect" Breaker Located on the Wall next to the condensing Unit Before you do any work. Replace when you are done..
Hope i Helped
Please Rate Me
Thanks
George
Apr 28, 2009 | Heating & Cooling
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
