Question about Lexmark X2600 InkJet Printer
Ink cartridge installed backwards
I instralled an ink cartridge backwards on our pitney bowes mailstation and now it won't unlock to let me get it out!
    Problem Solver:
  • 8 Answers
Use a non magnetized screwdriver and take the top cover off then unscrew the screws holding the guide bar in and gently pull the ink cartrige out you may reuse the cartrige but not recommended.
Posted on May 26, 2009
Remedy for "No ink tank detected"
Can be one of 4 probl0.
1. Bad ink cartridges
2. The gold pins that make contact withtthe ink cartridge are bent,happens a lot w withgeneric ink.
3. The print carriage is bad
4. The system boardis bad.
End users can only fix the first 2, the others should be covered by thepPitney Bowes warranty
Sep 10, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
How can I reset my pitney bowes ink cartridge
The ink cartridges should notbe reset or reused, rregardless ofwwhat some refill places tell you they are made for a single use & refilled ccartridges frequently leak or clog the lines in the meter.
If you are referringto the waste ink ttan, that can be reset using the tech code 6946 then press refill ppostag, go thru the menu todiagnostics, printer, page down & rreplace waste tank & reset. ONLY DO THIS IF YOU ACTUALLY REPLACE THE WASTE TANK.
Jul 09, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Postage meter is saying a connection cannot be made to call support
This frequently happens when the location uses digital telephone lines. The meter is more specific than fax machines and does not work reliably on any phonelline that is not true analog like an old home phone line before vonage & cable phone service.
Alternatively you can connect thru the Internetusing a usb cable and pc/laptop with Pitney Bowes pc meter connect software which is free on Pitney Boweswwebsite or the larger model meters can connect directly to a corporate networkwwithouta pc aas middleman.
Apr 01, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Replacement ink
clean touch point of cartridge both side
Mar 31, 2014 | Pitney Bowes IMAGISTICS OCE IM3511,IM4511...
Pitney Bowes P700 has a a blue screen
I just spoke with a service rep because at startup, our screen would completely fill in. To set it back to default, unplug everything and when you re-plug it in, hold down the 4 button until it's done Initializing. This should reset everything. If you need to adjust the contrast, hit the options button, then it will be the 3rd button down on the left and the top button will become 'increase contrast' while the middle button will be 'decrease contrast'. Hope this helps!
Sep 14, 2012 | Pitney Bowes Postage Meter DM100i, DM200L,...
Left cartridge inncorrect
It would be better to fix it with pitney bowes ink cartridge 793-5. You should try to replace yours with this one for easy fixing.
May 26, 2012 | Lexmark X5495 Printer
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
I refilled the black ink for my printer. I cleaned the printer .
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Brother cartridge... see if that solves the problem. Which it very well could work off the Brother again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
May 11, 2009 | Brother MFC-3240C All-In-One InkJet...
Lexmark X2580 won't print after cartridge refill
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Lexmark cartridge... see if that solves the problem. Which it very well could work off the Lexmark brand again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
May 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Lexmark X2600 InkJet Printer Logo
466 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
