Question about Buffalo Technology HD-HC320U2 320 GB USB 2.0 Hard Drive
My drive will now only start in the "Manual" power mode but my computer does not see it. I dont know why this is happening. Can I still pull the data and transfer to a new drive?
  • vincent391 May 26, 2009
    Thank you Chris!
  • 696 Answers
Yes you can Vincent,
However, as it is not showing up the controller in the Buffalo case is most likely dead. You will need to take it to a local computer store and purchase a new enclosure to put it in, then you should be ok.
If it doesn't work in the new enclosure then you have an actual HDD problem and may need the help of a pro. Let me know if this is the case and I'll make a recommendation based on your location(need to know location).
Hope this helps FixYa,
Chris
Posted on May 26, 2009
When turbo boost is over 30 psi and truck goes into exhaust cleaning mode all boost pressure is lost, and consequently all power as well. The only way to get boost back is to pull over turn truck off for 4...
i assume you are driving a 2008 superduty with a 6.4 liter. it should not lose power when in cleaning mode thatg is that drasticaly noticeable. be sure your maintenace is up to date. the first thnig our shop manual tells us is to check oil change and to change as needed. if you havent noticed the oil leel "grows" as you drive, if it gets high enough it can have an adverse afect on the engines performance. be sure to use original equiptment filters, and i suggest full synthetic motorcraft diesel oil. as a second note to your concern, there is/was a recall on performance for the 6.4 liter, recall #11b23. it is a computer upgrade for the engine, this too may help. your engine carries a 5 year 100,000 warranty from ford, if still under this, i would strongly suggest checkeding for recalls, oil change and seeing your local ford dealer! hope this helps ya!
Jun 17, 2011 | Ford F-350 Super Duty Cars & Trucks
I dont know why my external hard drive isnt showing up on my computer i think its lock, i dont know how it happen it was working fine a couple of days ago.
If the power light is on then I would get a new USB cable for it. If the power light is not on then you might need a new power cord.
Mar 04, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
When my desktop computer is in standby mode, I move the mouse and I hear everything start up like normal but now the monitor dont turn on and the green light above my " num lock" turn's on. I...
For windows 7 you have to change the power settings and stop it from hibernating.Go to control panel. Go to System And Security. Go to power options / Change when the computer sleeps and change that setting to never. It gets locked in a perpetual loop when it hibernates and locks up..
Feb 18, 2011 | Computers & Internet
Sorry for the repost but i have had trouble responding to your experts for some reason the comment window won't allow me to type from iPad. Anyway, after the hard drive issues which will be solved by the...
Flashing power light indicates that there's a problem with the RAM. You're referring to a Standy by mode when you turned on the computer. If you have a spare ram you can try to use 1 to check if the RAM that you're using is faulty. Mobo is fine dont need to worry about that. No need to remove the CMOS battery. If you know someone who has the same ram or another computer you can try that. Usually it happens to Desktop Computers that monitor was on standby mode when they have a bad ram.
Thanks for using Fixya.
Feb 11, 2011 | Gateway 4542GP Notebook
Hello no cdrom drive....eee pc900 wont boot up it...just keeps re booting and asking me start normal or safe mode i.e. can I get the recovery system copied to my usb for boot and system restore or mfg...
HI
Have you tried to start windows normally if so what happened because sometimes if the computer shuts down incorrectly when you restart it does ask you those questions so will you try to hit the start windows normally and if it dosent work let us know what happens next
Also try to start in safe mode and then do a system restore back to when it was working fine
we dont normally revert back to factory settings unless we have no other choice because you loose everything thats on your c drive and then you have a lot of work and updates to get it back to how you like it
So only do this if you really have to or you want to totaly clean and tidy it up
To do this i believe :-
Turn on the power swich and keep hitting the r key a few times that will hopefully take you into the restore area then follow the instructions
Hope this has helped you good luck
Nov 14, 2010 | ASUS Eee 4G Notebook
My mem card will only let me move pictures from my cell TO my computer but not also FROM my computer to my cell like it used to before it says "Remove the write on protection or use another disk" i dont...
This should help fix the issue,
You will have to open MY Computer or COMPUTER from Start button. Make sure the SD Card is connected to PC.
1) In My Computer, right click on the drive letter of your SD card and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, Proceed with your copying.
5) If it DIDN'T work, repeat steps 1 through 4 ( 2-3 times )
If this does not work, there is alternate method.
The Memory card has a write protect slider on the side. Try putting tape around the card to make sure that the slider thing does not slip into write protect mode when inserting the card.
Sep 07, 2010 | SanDisk 2GB microSD Memory Card
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
My memory stick won't open from the my computer page. i says access denied. I have to pull it out and put it back in the drive again to open it.
it happens some times...if u are able to acces it u should not be cribbing about it...USB hardwares some times dont switch off when u switch off the PC/laptop, so some power remains in it...and when u switch on the machine the device is in sleep mode and comes alive only when u pull it out...
check ur USB Root hub under USB serial Buss /device manager setting in Device Manager/Properties/Power Management...is it turned to OFF ?
Uncheck the tickmark to ensure that the computer does not turn off the USB device to save power....
this could also be one reason for ur memory stick to sleep when not in use...
all the best
Dec 25, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computer in power safe mode, keyboard and mouse don't work
Hi there
Start the computer, insert the SIMS game CD again, wait untill the game start up, - now, shut down the game while the CD is in the drive.
regards /Teis plz let me know if you get your problem solved.
Jan 04, 2009 | Dell Dimension 2400 PC Desktop
Power issue
plz check if there is any disc in the drive?
if not this time the system restart keep tapping on f 8
and go to safe mode type msconfig in run clk ok
new win will *** up go to startup tab down at bottom disable all
apply ok restart teh computer clk on the chk box dont show this mesg again once the computer will boot let me know if teh thing doesnt work
May 22, 2008 | Compaq Presario 700 470024-192 Notebook
Buffalo Technology HD-HC320U2 320 GB USB 2.0 Hard Drive Logo
71 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
