Question about AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP SOCKET A KT400 ATX 3GB DDR 333 (MTH2022AS)
No signal on monitor
Pc worked fine for 2 or 3 years then as soon as i turn on pc monitor says no signal n light turns yellow, power supply is 400 watt nvidia grapic card 5500 Lx 256 mb, amd 2200 3 sticks ram 512 mb ddr333 mobo ASUS A7V8X-x KT400 things i tried 1 new processor (went from amd 2200 to amd 2700 switched few times reseated several times) 2 reset cmos (removed battery n power cord moved jumper then reset all) 3 removed everything to old mobo. hard drive, vid card, ram, power supply, everything worked except mouse n keyboard so not alot i could do there. 4 removed ram tried different combo's to ensure ram was good. i would think it something to do with processor but cant see why wouldnt work after i switched them. maybe mother board is fried? i wanted to get this to work for kids on internet and was going to buy a new one for me any suggestions?
  • seh3271 May 26, 2009
    and yes i checked all cables to make sure they were tightened
  • seh3271 May 27, 2009
    thnx give it a shot
    Problem Solver:
  • 11 Answers
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
Posted on May 26, 2009
Monitor can't get a signal from computer
Monitor is working fine so... Check on the CPU... You might see it running but not. While the PC is OFF and power cable is disconnected, try removing the memory and clean it with pencil eraser, put it back carefully, check also vga / pci cards then turn it back ON... that will work.
Apr 29, 2012 | Acer Veriton Computers & Internet
Blue light goes out yellow light stays on after computer is turn off
User manual: http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
That is normal condition, yellow = no video signal from PC since PC is off or PC in standby mode.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
I have a HPw1907 monitor and it will turn on for about 2 seconds, and it turns off. The CPU is fine, just a problem with the monitor. Any way to fix this?
We have the same model of monitor and had the same problem few days ago. The monitor just goes black/turns off. I noticed that the power button has a yellow blinking light and cannot be turn on/off again using the power button. The CPU is working fine also. When I turn off the avr, the power button's light turns blue for a few second and you can hear a click sound from the back of the lcd before it totally turns off. My lcd monitor is over a year old now and is 110v or 220v capable. Mine was originally in a 220v, i just put it in 110v and the monitor was fixed.. Hope this can somehow fix your problem.
Aug 02, 2009 | HP w1907 LCD Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Dell dimension 4700 blinking yellow light
Are you getting any beep signals? You could have a massive motherboard failure or you could be having something a little easier to fix...like a memory failure...do a little research on beep codes on google if you are getting beeps from the motherboard...Also, try opening your machine and pulling out the memory sticks and trying them one at a time...if the machine works with one and not the other (for example) then you may need to simply replace that bad stick of memory...
Apr 08, 2009 | Dell OptiPlex SX280 PC Desktop
Monitor says no signal
cheak ram u can get power 400 watts highter atx style with 2 rails but might be bad video card or it defulted to other slot
Jan 25, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computers & Internet Logo
248 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
