Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
No picture spiral wave inthe center of the screen wHEN I TURN IT ON NO PITCURE IS AVAILABE JUST A BLUE SCREEN. I HAVE TO CUT IT OFF AND ON TO EVENTUALLY GET A PICTURE
    Scholar:
  • 174 Answers
Let your local TV repairman check it. Don't touch anything inside it nor open it.
Posted on May 26, 2009
Can not remove the large spiral bevel gear
The large spiral gear is pressed tightly on the spindle then held in place by a wave washer and retaining ring. After removing the retaining ring and washer, you have to use a press to push the spindle out of the gear.
Feb 06, 2013 | Makita Grinder 115mm - 9554NB
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
The colors are kind of 3d and not focused there is a wave of blue green and red that dips down in the center of the screen. is there some way to focAS THE LAMPS OR SOMTHING TO MAKE THE PICTURE MORE CLEER?
u have 2 problems one is the convergence ic and also u need a oil chage on picture tube blue a green , maybe total repair $400 , u need to contac a tv shop for thie job
Apr 13, 2010 | Philips 43P8341 43" Rear Projection...
Hitachi 43fdx11b green wave on top left/center of screen
Check your soldering.
Check the resistors - make sure none are shorted.
Make sure you did not buy fake STK chips...
www.TvRepairKits.com
Feb 15, 2009 | Sony KP-51HW40 51" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Picture on screen is to big for screen
HELLO. IT SOUND'S LIKE SOME ONE HAVE TURNED UP THE V HIGHT ON YOUR SET. THERE SHOUND BE A CONTROL POD .!!! ON THE BACK OF YOR SET .!!! FOR THIS OR.!!! IT'S ON THE IN SIDE OF YOUR SET.!!! ON THE MAIN CHASSIE. .!!! YOU SOULD LOOK FOR IT.!!! AND TURN IT DOWN.!!! BUY TURNING IT CONNTER CLOCK WISE.!!! WITH A SMALL SCEWDRIVER.!!! TURN IT ABOUT 1/16MM. VERRY LITTLE.!!! LOOKING FOR THE VERTICAL SECTION ON THE CHASSIE YOU SHOULD SEE A SMALL POD .!!! WITH A V-HIGHT.!!! OR ONE WITH.!!! A (V-LENTERY).!!! THE HIGHT POD IS FOR THE CENTER OF YOUR SET UP..!!! & THE V-LENTERY .IS FOR THE CENTER OF YOUR SET GOING DOWN.!!! ONE IS FOR UP.!!! AND THE OTHER IS FOR THE PITCURE TO GO DOWN.!!! TURN THE UP CONNTER CLOCK WISE.!!! 1/16 MM. FISRT.!!! THAT SHOULD BRING YOUR PITCURE DOWN.!!! REMBER TO FIRST .!!! TO UNPLUG YOUR SET.!!! BEFORE TRY THIS.!!! AFTER UN[PLUGING IT DO THE AJUSTMENT.!!! THEN PLUG IT IN AND SEE WHAT HAPPEN.!!! REPET.!! TILL YOU HAVE IT TO THE HIGHT YOU WANT.!!! HOPE THIS HELP'S YOU .!!! LET ME KNOW.!!! OK " GOOD LUCK"
Aug 13, 2008 | Philips Televison & Video
Strange screen colours
Your degaussing circuit is not fully 'demagnetizing' the picture tube.
You can manually degauss it using a strong magnet, but it's tricky.
With a tool made for demagnetizing you simply hold it close to the center of the picture tube and using a circular motion slowly spiral outward to the outer edge of the tube, pulling the magent further away from the tube at the same time. The same can be done using a strong magnet although the results may not be perfect. You can experiment with a magnet using wiping motions as you bring the magnet closer to and further away from the tube.
Mar 05, 2008 | Beko 324250WN 28" TV
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
No picture
mine does the same thing , i leave it on for a few min's then off and back on and it works fine
Oct 21, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
151 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
