Question about Hitachi 53UDX10B 53" Rear Projection Television
Hit 53UWX10BA All of a sudden, the picture is diplaying a blue ghost and yellow shadows. I noticed that some of the text is displaying a second image of blue for the same text. Somewhat like a ghost image. I apprecriate any help. John
  • 7 more comments
  • mayjp Oct 21, 2007
    I forget to mention that when I press magic focus. It displays a 3 at the end of it. 3 must be an error code. where are the codes.
  • Anonymous Nov 05, 2007
    I have the same exact problem but it has nothing to do with cable or television reception. I disconnected the cablebox and put in a movie and the television set still has a ghosting problem with significant yellow and blue ghosts. Any suggestions with dealing directly with the television? Thanks!
  • Anonymous Nov 11, 2007
    our tv had the same problem but with the red and green, with double display of words, magic focus displays a 5 at the end
  • gilcurameng Jul 01, 2008
    I have the same exact model tv and same problem with blue ghosting. When I press the magic focus, 4 appears at the end. When I press the service button on my convergence board it shows the red and green are perfectly aligned but the is mis-aligned. The top three line has a sag and the bottom three lines has a crest. I tried manually adjusting the sag and the crest but it will only let me adjust it so far and then I can't adjust it any further.
  • Anonymous Jul 02, 2008
    the letters has blue and red color separating
    Same started with error code 3 now 4. Magic fix worked once but once turned off now it has blue and yellow shadows.
  • poshey Oct 01, 2008
    I have the same problem with a blue and yellow ghost and when I turn the tv off and back on it goes away.
  • hoyjohn Oct 02, 2008
    I have the same problem, and the cable box solution doesn't work for me as the TV changed states but the cable box didn't. the problem followed the TV, and all my other TV's work fine.
  • emeryd15 Nov 30, 2008
    I also have the same problem. Blue shadows on picture. When I run magic focus I get a 4 at the end with no correction to the picture.
Check you cable box compared to another tv.  The pisture may need adjusting take off front panle and use the screws to adjust pic  it could get better of worst be carefull
Posted on Oct 26, 2007
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Samsung SP43T6HCX displaying ghost images
May be it is effected with a virus
Apr 20, 2009 | Televison & Video
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
Feb 16, 2009 | HP L1706 17" LCD Monitor
Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Oct 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Porjector
Hi there
Is it a LCD or DLP ?
First try using a different cable. If the problem stil occurs this might be a faulty Mainboard - which would need either repair or replacement.
Does the discolouration show in the startup screen as well ?
Apr 17, 2008 | Office Equipment & Supplies
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
250 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
