Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Need to clean the heads but can't find instructions to do it.
I need to run a cleaning procedure on my Kodak ESP3 AiO printer, but I can't find where it is on the software.
    Problem Solver:
  • 8 Answers
To clean the printhead press: COPY and CANCEL at the same time.
To print a test page press: QUALTITY and CANCEL at the same time.
Go to Kodak AIO home center, click on the"?" and open the "user guide" for the complete manual. Wish they put in a printed version, put they don't. Good luck with the printer, mind has been nothing but problems. And keep trick of what you print. You will be shocked at the low output. Report it to Kodak and they might sent you new inks.
Bob D.
Posted on Aug 22, 2009
Kodak software removal problem
Sure, its very simple. You log onto www.kodak.com/go/clear and follow the online prompts to run the clear tool.
May 04, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Several months ago I received an email from Kodak recommending that I install an update to the driver for my ESP3 printer so I did only to find that there were some incompatibility problems which I worked...
download the software and then run it as administrator. before thet go to www.kodak.com/go/clear and download clear utility for kodak aio software and then run it. what it will do is remove all the files and folders of previous kodak software.. then install vista version from internet and run it as administrator.ur issue will be resolved
Jul 28, 2009 | Kodak Office Equipment & Supplies
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Cannot download or install kodak esp3 aio drivers or software
either you have 64 bit op system or you dowmloaded the wrong driver on accident.
if this information helps please use fixa when rating. thanks
Apr 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Uninstall kodak easyshare
Hi there
Thanks for posting your problem on fixya
Thanks for providing us all the details you unable to install because you have aio still on your pc so please do these simple steps
click on start>> go to run>> type >>msconfig>> and go to startup and find that aio and please uncheck that aio and reboot your pc.
After rebooting your pc you are able to install what u want
if this solution works then please vote for me
Thanks
Robert
Sep 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
AIO Home Center Problems
i click on the eyecon and this kodax aio home center encountered a problem and needs to close pop ups
May 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
353 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
