Question about Kenmore Microwave Ovens
No heating Kenmore Model No. 665-4438911 Microwave (wall unit) quit heating this morning. There is still power to the unit (clock), but light in the unit doesn't work. Used it to heat some dog food, then it didn't work when heating the next plate of cat food. There is an audible click, but no light or heating.
  • blackoakfarm May 26, 2009
    That pretty much confirms my suspicions. It's a 19 year old model and replacing it is probably what I'll do. Thanks.
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Does not heat anymore, power is going to unit, the clock, and fan work, light still works but it will not heat and makes a low growling sound when we try to run it. Help!
What you are describing is a problem with the magnetron and it has become faulty, that is the main part that heats the food, the growling sound indicates it is loading down the power transformer that energizes the magnetron. The repair cost will not justify the expense "costly" replacement of the microwave oven "cheaper" in the long run.
Jan 21, 2011 | Kenmore 80412 Microwave Oven
Have ge spacemaker xl micowave--model jvm 1653.......has always worked without a flaw--------now most every morning as attempting to use--starts and then instantlly quits----xxxxxxx across read-out --and...
Your losing power to the unit. Bad breaker or bad outlet. Loose wire at breaker or outlet. when you run it and it gets a little hot the connection expands and makes better contact, and that is why it works through out the day and then quits after it sits for a while, then is coos and contracts again.
Jul 26, 2017 | Microwave Ovens
Microwave KOT151S under counter model quit working right after installation. Power from house is funtioning, but the only thing working on microwave is the interior light. Is there a built-in fuse within...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If some keys are still unresponsive, your membrane keypad has failed.
This can be due exposure to excessive heat, moisture or condensation, such as
due to storage in an unheated building.
It's usually economical to order a whole new controller here.
Let us know if we can help you further.
Aug 21, 2010 | Kenmore 80412 Microwave Oven
Our Kenmore microwave started emitting odors and then quit
To figure out what is wrong with it, it will have to be removed from the wall, Then the top cover will have to be removed, then you can look for any swelled capacitors, burn marks on the circuit board or any shorted wires.
The power supply is most likely faulty . You can test the power with a voltmeter from power supply to main circuit board.
Oct 28, 2009 | Microwave Ovens
Microwave just quit working
Hi , Open the cover unsscrew it , be sure to unplug power ,if you have continuety tester , test the fuse if open replace it , is also availble in appliance parts center near you.
Feb 13, 2008 | Kenmore 62702 Microwave Oven
Kenmore Microwave Problem
"d" may mean demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
Oct 13, 2007 | Microwave Ovens
Kenmore 665.61629100 Microwave Problem
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
Oct 13, 2007 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
177 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
