Question about Olympus FE-180 Digital Camera
Card error What does it mean when the camera says card error, format or power off
    Brigadier General:
  • 6,966 Answers
Card error message requires that you re-format the  memory card of your digicam.
Good luck and kind regards.
Posted on Oct 21, 2007
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
What does "memory card error" mean
It usually means that you are using an SDHC card in a camera that only understands SD cards. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If that isn't the problem, it may mean that your card needs formatting or has become corrupted, which will be fixed by formatting it. Formatting deletes everything on the card.
If that isn't the problem, then there may be a fault with the card or camera.
Dec 09, 2010 | Canon PowerShot A530 Digital Camera
The sd card is not working and saying card error
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that :
Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
Nov 10, 2010 | Canon Elura 90 Mini DV Digital Camcorder
I'm getting a "card error" with my existing memory card when I power on. I purchased a new card and receive the same error. Thanks, Todd
This usually means the card needs to be formatted in the camera. If you have pictures on it, download them first using a card reader if necessary.
Nov 10, 2009 | Samsung NV10 Digital Camera
My daughters olympus FE190 when switched on asks you to Format or Power Off. If you choose Format it switches itself off and if you choose Power Off is then gives you Card Error. Does this mean the...
The largest xD card which can be used in this camera is 2GB. If the card is larger than that then it wont work. This camera has both internal and card memory. Try using the camera without the card or with a smaller card.
May 14, 2008 | Cameras
Faulty memory card - card error.
hi, May be, it is possible, but take a chance, try with another memory card, i hope you will get it from your friends. check the camera with that, if camera works properly means problem in your memory card.If camera not works means,there is something wrong in card accessing circuit of camera. If so go to olympus shop. also try to format your memory card with pc and then check the camera with that. good luck
Aug 01, 2006 | Olympus Camedia C-300 Zoom Digital Camera
The camera screen displays a "Memory card requires formatting" error message. What should I do?
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
The camera screen displays error message
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Olympus FE-180 Digital Camera Logo
75 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
