Question about Saeco Magic De Luxe Espresso Machine
Steam peters out after 20-30 seconds
Newly purchased, refurbished Saeco Magic deLuxe only steams for maybe 30 seconds before turning into a dribble of water. For those first 30 seconds, it is steaming like a pro! FYI -- brew works fine as does the hot water dispenser. What could cause the steam function to peter out like that? Turning it off for a short while will allow it to build up pressure again, but if you then turn the steam on, it will again last only a short while. Tank is 2/3 to 3/4 full.
  • 3 more comments
  • actorschu May 27, 2009
    Thanks for the response. Yes, the pump is pulsing away. And it really steams like a champ for the first 20 seconds, then it slows to a light flow of water by the 30 second mark. It's as if it has lost all of the pressure it had built up.
    The machine was just received, so I'm not sure when it was last descaled. Since it is a newly refurbished machine, I'd expect that they either descaled it or at least checked the boiler to see if it needed it. Or maybe I'm asking too much? :-)
    And to comment on Solution #1, thanks for the thought. I have an older Magic Deluxe that steams just fine, so I switched Parnellos. No luck! The steam still petered out to nothing after 30 seconds while the pump was chugging away at about three clicks per second (about the same rate as the working, older machine).
  • actorschu Jun 01, 2009
    Thanks all for the helpful hints. The machine was still under warranty, so I just bit the bullet and sent it in for repair/exchange. Hate to be without it for another week, but will feel better getting the issue addressed properly.
    Thanks!
  • bansheracer May 11, 2010
    When was the last time you descaled the mahine? There is a mineral in all water that makes it sweet, that is calcium carbonate and that builds up in the boiler and needs to be removed by descaling. Citric acid powder is what you need to use.
    Hi
    Do you hear the pump pulsing when it is the steam mode when you open the knob?
  • 1,089 Answers
Hi
Do you get a red light over your temperature or does it stay green.
I would do a descale just to make sure that that is not the problem.
Posted on May 28, 2009
    President:
  • 1,618 Answers
The only thing that I can think of (not being able to see the machine) is the Parnello. Reason; steam is comming out faster than the element can heat it up. At some point it has to be restricted, for a nice uninterrupted flow.
Posted on May 27, 2009
  • Ernest R
    Ernest R May 27, 2009
    This might sound crazy but try it, open the steam wand and when it stops steaming, push in on the steam knob.
What PURGE means
Means to run Hot water through the steam wand... Also called ventilating the machine. Basically running water through the machine the easiest way possible which would be through the steam wand. On the magic deluxe all you have to do it turn the steam knob.
here is a page that may help you now or maybe some other time. http://www.cerinicoffee.com/item-group.asp?pgpID=13
Jun 06, 2011 | Saeco Magic De Luxe Espresso Machine
My saeco magic coffee machine says ventilate.How do I do this?
Hi
If it is just a Magic Delux, open the steam knob, without pushing the steam button. If its a Magic Comfort you have to push the button with the drops on it and it will flow water.
Apr 10, 2010 | Saeco Magic De Luxe Espresso Machine
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
The steam knob only turns 1/4 turn to left
Hi
!/4 turn is all the Magic and Royal machines will do. Don't try to turn it farther or you could break the steam valve.
Dec 26, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Magic deLuxe shorting
this is from steam condinsation inside the unit (check all hoses for leaks also check seals!)
Please rate responce and help keep this site free!
Dec 20, 2008 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
135 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
