Question about Dell Inspiron 6000 Notebook
Laptop AC Adaptor
When i plug the AC adaptor into the laptop to charge the battery the light on the AC Adaptor turns off, when i take the AC Adaptor out the light comes back on.
  • 696 Answers
If the light is going out whenever you plug the Ac adapter in you most likely have a short in the laptop. The most likely culprits are a failed battery or a damaged AC port. Remove the battery and AC the use a pen or pocket knife to wiggle the pin in the center of the AC port. If it is solid, it's probably good, if it wiggles it's likely broken(may need a pro for this repair).
Assuming it's ok, leave the battery out and try plugging the AC back in. If the light goes out the problem is likely on the motherboard and may need a pro. If the light on the AC pack stays on turn on the laptop, if that works the battery is the problem, you can purchase a new battery.
Try these and let me know how you make out,
Chris
Posted on May 26, 2009
  • 115 Answers
Look here the problem can be of two types,,first the problem can be of the adapter or the port in the computer where the adapter pluggs in the computer,,look for any friends or relatives using the same computer with the same good adapter,,plugg it into the computer,,if u dnt c the problem then prob with the adapter or else prob with motherboard
best of luck,,keep me posted,,giv agood rating
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
AC Adaptor not working in laptop
the problem is in your laptop...maybe it damaged too when you plugged your old adaptor. you should check your laptop for a repair...maybe it needs to replace tha spare parts that may have been damaged.
Dec 01, 2011 | Computers & Internet
My battery is low and when I plug the power cord into the laptop the light that was on on the adapter turns off and my laptop will not turn on. I have a Dell Inspiron 6400
I'm assuming you are using a GENUINE Dell laptop charger designed for this model?
Check the end of the adaptor, if it is the type that has the centre pin, make sure it has not snapped off.
Check the adaptor is putting out 20 volts DC by connecting a multimeter to the outer and inner parts of the DC jack.
Usually, the ac adaptor LED will flash green if there is no charge going to the laptop ("spitting back power"), however, a dead adaptor is often recognised by a lack of the lED light glowing
You can try with a universal adaptor, it will not charge the battery but at least will eliminate the charger or the charging circuit. If this also fails to power up the laptop, then the issue lies with damage to the motherboard
Jan 21, 2011 | Computers & Internet
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Ac Adaptor not working??
as u said that when u plugged in the ac adaptor into the laptop it recognises that the ac adaptor is connected but it does not charge the laptop in this case what u can do is that if have the same charger extra then u can try with the another charger and if the other charger also does the same thing then in this case u need to replace the mmotherboard and if the other charger is working fine in this laptop then definately chage ur aac adaptor.....good luck...
thanks
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 6000 Notebook Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
