Question about Canon PowerShot A70 Digital Camera
Flashing lights on screen
Cannot take pictures. when camera is turned on display screen shows as normal. the screen then goes blank and horizontal flashing lights appear on the screen.
  • fmattox1 May 27, 2009
    I don't know but I am going to try to send to canon
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 26, 2009
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
View screen lights up but no display
if u see white screen or noisy picture on lcd and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my Fuji S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 08, 2009 | Fuji FinePix 2650 Digital Camera
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Screen goes blank after clicking a picture
This is the normal cycle time and it can increase if the batteries are a bit weak. This is one of the minor issues with this camera. You should only notice this when using a flash since it has to re-charge the flash circuit, without flash the picture should retuen in a second or less.
Sep 16, 2008 | Canon PowerShot A620 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Canon PowerShot A70 Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
