Question about HP Compaq Evo Notebook N610c
Pink screen sometimes when i turn on my evo n610c, the screen has a pink tint to it for a while. after it warms up, this quits. what do i gotta buy and around how much would that be
  • 916 Answers
It sounds like a bad inverter. A local service technician should be able to do it for under $100. Here the rate is about $70.
Posted on May 26, 2009
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
I have a Compaq Evo N610C laptop and the screen flickers and then goes out
Take a good look, can you still see the image?
From your short description it should be a power-inverter problem.
Checkout google on used parts, buy a power-inverter to that computer model, unscrew the screen, take the cover, and you should see the power-inverter. Replace it.
Sep 14, 2009 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Gotta problem
Hold down the Fn button on the lower left corner of the keyboard and the F2 key @ the same time.
The light on the front of the lid should light up. If it doesn't follow this link and there is an update there that should get you up and going.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316666&prodTypeId=321957&prodSeriesId=316664&swLang=8&taskId=135&swEnvOID=1098#120
Dec 30, 2008 | HP Compaq Evo n610c Notebook
Pink screen
Dear LT user,
Your LT has one of the following 2 problems: Your LCD cable might be faulty OR your inverter board is malfunctioning.
The LCD cable is responsible for transfering "color information" or "screen data" from the motherboard to your screen. If this cable is faulty or malfunctions, it can result in a lot of appearances - in your case a pink screen.
The Inverter board is repsonsible for the "light" on your screen. If the inverter board is faulty or does not function properly, you might experience this issue.
If your LT is still under waranty, you can give it in @ the nearst HP Warany centre for repairs. If not ; HP parts are very expensive.
What you can also do, you could install an external monitor (LCD flatscreen) to your LT. Because the Flatscreen cable connects to your VGA port at the back of your LT, using an 15 pin blue connector , it connects directly to the Mainboard so it does not run over the LCD cable and thus will be a unit on its own.
Kind Regards,
Stef
Apr 16, 2008 | Compaq Evo N610C Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
Unusual Blue tint on LCD
something wrong connection inside video system lose wiring or plugs.
Dec 30, 2007 | Compaq Evo N610C Notebook
HP Compaq Evo Notebook N610c Logo
126 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
