Question about Epson Office Equipment & Supplies
I have an Epson Perfection 1650 and the computer has Vista. I am trying to scan slides and put them in a file to later transfer to a disc. I am having no luck at acomplishing this task. dkirk228@embarqmail.com
  • dkirk228 May 26, 2009
    /Your solution did not solve the problem. After the scan the 4 slide photo's all show up in the thumbnail as one picture and this is not as it is supposed to. Each slide should appear as one photo. With a previous computer I have scanned over 1800 slides and had no problems. Is this procedure compatible with VISTA ?? Is there a download needed to correct any problems and how would I accomplish this?
    My comment to your second suggestion is that it didn't solve the problem or even come close. I will not accept in more of your suggestions. Besides you didn't even answer the questions I asked about being compatable with Vista. I have found info in Epson's information on line which states it is not compatable with Vista. Rather than continue any further with this avenue of scanning slides I will purchase another scanner that will do what I need and be way further ahead money wise in the long run. Thanks very much for trying. Dwight Kirk
  • Epson Master
  • 19,396 Answers
You need to scan in full auto mode when using the Epson scanner software , follow the instructions here to scan slides.
After scanning you will need to save the slides one by one on single files, save all files in a folder and use the CD burning software to save them on a CD.
Posted on May 26, 2009
  • 1 more comment
  • Ginko
    Ginko May 26, 2009
    In that case try switching to professional mode and enter settings manually, click here to see instructions.
    Regarding other software, yes you can use third party Twain interface to manage the scanner, but it will be even more difficult to find a proper setting for your slides.
  • Ginko
    Ginko May 26, 2009
    The software is Vista compatible, and not only, the software is working fine.
    When the software is not compatible and not working you get no scan at all, and the software does not start and does not work on vista , therefore this is not a software compatibility problem.
    the problem is with settings or with the way slides are being placed on scanner.
    To scan slides you need to do a pre scan first , then select the sccanning area to a single slide, otherwise you will get all slides scanned at once.
  • Ginko
    Ginko May 26, 2009
    I wanted to add that the scanner is surely Vista compatible, here is Epson page where it shows Vista 32 drivers as first software download, that means that the scanner had been designed to work on Vista.
    The info that you found was probably just the opinion from a user.
    here is the page:
    Epson Perfection 1650 Photo, Drivers & Downloads
    Here also Vista compatibility list, including your model:
    Scanners
    Just do a pre scan, then select the scanning area using the mouse, so to scan a single slide at a time.After that save each scan as a single file.
    Thanks for your patience.
    G.
I have an older Epson 1650 scanner I have never used. Once set up, and plugged in the scan button flashes red, indicating error. It is obvioius that the fluroescent light is turning on. I am...
If you do not have the manual for this product, you can download it at Epson.com. Also make sure that the lamp lock has been disengaged. It's usually located under the lid or on the bottom of the scanner. This prevents damage during shipping but will give an error if it's engaged when you warm it up. Good luck.
Mar 07, 2011 | Epson Perfection 1650 Photo Flatbed...
Scanning Slides from Epson Perfection V700PRO
Hi
Please reinstall Epson Scanner software it will solve your problem
Thanks
Apr 11, 2008 | Epson Perfection V700 PHOTO Flatbed...
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
I just installed a 1650 scanner and I have no choices in the document source window. I need to scan color slides. I'm running Vista
I believe you need to change your settings to professional, right now its in automatic or beginner.
something like that
thanks adi
Dec 16, 2009 | Epson Perfection 1650 Photo Flatbed...
How do I scan a slide photo / negitive on my epson perfection V200 scanner?
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
Aug 08, 2009 | Epson Perfection V200 Flatbed Scanner
I need to reinstall my epson perfection 1650 but i can't seem to down load the driver or printer software i don't know what i need i have window vista 32 bit and i have the epson scanner perfection 1650...
Copy and paste this link in your internet browser address bar and you will be taken to the site to download all the needed drivers:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14551&prodoid=6464130&infoType=Downloads&platform=Windows
Do give my solution the highest rating if it solves your problem. Thank you for using fixya!
Aug 07, 2009 | Epson Office Equipment & Supplies
Scanning slides -
Do try reinstalling the fotware this is where the trouble lies.
Or
Save the scans and in a suitable photo Editor revers the image Neg to Pos
Dec 29, 2007 | Epson Perfection 1660 Photo Flatbed...
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
