Hi there!
I have a Sharp LC-37D5U LCD tv. The unit was working fine. After being on for 3 hours, it turned itself off with an audible click. The OPC/DL led flashes 1x per second constantly. We unplugged the unit from the power source and the light stopped flashing. When we plugged it back in, the power led (blue) will light up, the unit will click twice and then the OPC/DL light will resume flashing 1x per second.
We tried to reset the unit (buttons on rear of tv) - no change.
We left the unit w/o power for 24 hrs - no change.
Some research indicates that the power supply may be faulty. Before I attempt to remove it, can anyone make any additional suggestions. I can't afford to take the unit to a repair shop (been unemployed for a bit), so any help/advise would be greatly appreciated. I have not been able to find much other information on this tv, except for this site. So, I'm hoping you can help me.
Thank you, in advance!
Sincerely,
Murray in Florida
Here's what I did to fix issues with my 37D5U - do at your own risk:
***Follow the instructions below to fix the same issue in your LC-37D5U tv***
Do this test first to confirm the failure:
(1) Connect the cable line to the tv.
(2) With the tv unplugged, hold down the Input and Volume-Down buttons simultaneously, then plug in the tv.
Expected result:
(a) You should hear the tv come on in the service mode; the OPC/DL and
power lights on the front of the tv should turn green and blue,
respectively.
(b) The broadcast sound should come through the speakers, but you will probably still have no picture or back light.
If your test yields the expected results, proceed to the fix.
Fix
Parts Needed
(1) Part type: Fuse
Location on circuit board: F705
Official Part No: QFS-A1154SNEZ
Replacement Part No: BK/PCB-1-R (Mfg: Cooper Bussmann - about $2) or the
original QFS-A1154SNEZ (Distributor: Sears Parts Direct - about $14)
(2) Part type: Mosfet (4 of them)
Location on circuit board: Q723, Q721, Q719, Q717
Official Part No: k3469
Replacement Part No: FQPF13N50C or FQPF13N50CF (Mfg: Fairchild Semiconductor - about $2 each)
Fuse F705 is part of the circuit on the power supply that powers the
inverter circuit, and the inverter switches on the back light for the
tv. The mosfet at location Q723 was suspect when I tested it, so I went
ahead and replaced it and the other three mosfets "chained" to it as
preventative maintenance. Parts can be bought from digikey.com - digikey
is usually a same-day shipper with the best prices, so I use them. USPS
Priority shipping is the best bang for your buck.
Tools Needed
Philips screwdriver
Soldering iron
Desoldering braid or some other solder remover
Light bulb socket that has two wires running from it and a clear
100-watt light bulb - Home Depot sells the sockets. Alternatively, you
can use a 2K ohm/10W resistor
Multimeter - not necessary, but helpful
Procedure
(1) **Important: Make sure the tv is unplugged**
(2) Remove the back cover and stand - there are a bunch of screws
holding the back cover on. You can either mark the screw locations and
bag the screws or do what I did: Unscrew the screws, leaving them in
their holes, then slowly lift the back cover off and carefully set it
down with the screws intact.
(3) Set the tv on a flat surface with LCD panel facedown and remove the AC power cable.
(4) The board you want to work on is the power supply board (see pic
below), which is the board where the AC power cable connects. Carefully
detach the connectors that connect to the other boards in the tv from
the power supply, then remove the screws that hold the power supply to
the back of the tv and lift it off the tv by holding it by its edges.
(5) Locate the four large 450V capacitors at locations C734, C709, C710,
and C852 without touching them (they look like soda cans). Flip over
the power supply board. Touch each wire of the socketed light bulb or
resistor for about 3 seconds to the negative and positive leads of each
large capacitor, respectively; polarity is irrelevant. This discharges
the high voltage from the capacitors so you don't get shocked while
working on the power supply. The voltage usually slowly dissipates on
its own, but it's better to be safe than sorry when you're talking about
a potentially lethal 450V. Check the voltage with your multimeter in
the appropriate DC mode to verify that the capacitor voltage has been
drained; if you don't have a multimeter, just continue on.
(6) At this point, you can verify that the fuse at location F705 (looks
like a small black box) has indeed failed by holding the multimeter's
red and black probes on the fuse's leads with the multimeter in
continuity mode. If you have no continuity, the fuse has internally
failed; proceed to the next step.
(7) Desolder the fuse from location F705 and desolder the mosfets from
locations Q723, Q721, Q719, and Q717 then replace with new components.
(8) Put the power supply board back in the tv, using just a couple
screws to hold it in for now. Reattach the connectors to the power
supply.
(9) Attach the broadcast cable line.
(10) Reconnect the AC power cable to the power supply (don't plug it
into the wall socket). Hold down "Input" and "Volume-Down"
simultaneously, then plug in the tv. The tv picture and sound should
come on.
(11) With a small screwdriver or other probing device, depress the Reset
button, not the System Reset button; it's the last recessed button
below the cable jack on the back of the tv. The tv will reset, then you
should get sound and a picture from channel 2.
(12) Reinstall the remaining power supply screws, back cover, and stand.
Sorry, step 4 mentions a picture, but there is no picture included. The power supply board will be apparent.
Thank you very much for your professional directions! I did fix invertor's part on power pcb before I tried to power it up. It was more, than a fuse, of course. 2 mosfets were shorted. after all those procedure, still blinks and won't turn on. Next, replaced 5 capacitors in standby power supply. Blinks, bastard! Only with your help of resetting the set, it came back to life, completely.
I feel a bit obligated to you and I also run TV repair business since 1992. Once in a while getting into this kind of situations, but I do have a big baggage of knowledge about anything what's talking and showing picture. Feel free to contact me. [email protected] . Sincerely, Alex.
I had the blinking power light symptom with the TV appearing otherwise dead. Pulling the power plug and then reinserting it with the Volume-Down and Input buttons depressed caused the TV to start normally. It now powers-down and powers-up normally.
